I have a Mikuni VM28 in my pile. Flatslide and actually part of the TM family, don't know why the designation is weird on the 28mm.
Would it be an upgrade over the 24/24 I'm currently running on my Stella? 177 Polini kit and Polini pipe.
Would it be worth going through the effort of changing intakes and such?
Also in my pile I have a Dio pyramid reed block setup that although made for a 50cc engine looks like it would flow a lot more air than the stock Stella flat reed. It's designed to be used with a 28mm carb. Looks like I could basically just cut a thick aluminum plate to create an adaptor to fit the Dio intake on there. Drill, drill, file, file, Bob's yer uncle brother wife.
