Castle nuts are stupid. Can we use this thread to source info to make a NSM WIKI article so I can google this in 2 years after I have forgotten?
I switched the clutch on a P200 motor and went to reinstall and couldn't get the castle nut retainer to line up to the nut to a satisfactory level. Also torquing these buggers with motor in the scoot is a #%£$*. No problem I had the BGM hexagon nut w/ Schnorr washer (BGM 7671201) on hand, why was I bothering with castle nuts anyway? Torque to 45 ft/lbs andddddddddd was stranded 5 miles later. No comms between transmission and crankshaft.
I removed the clutch cover and the clutch nut was backed out but still (barely) on the crankshaft . It obviously smoked the woodruff key but it put up a fight and had to tear its way off. It also took out the clutch back plate. Thankfully crankshaft survived.
After consulting with Birdnest, I most likely had the conical Schnorr washer pointed the wrong way. It should be pointy side to the nut. Slightly annoyed at my stupidity, but it was late and I didn't think through. Sharing my lesson to save you heart ache.
Once I get a new clutch back plate, I'm going to use the DRT SIP 11351940 nut & washer. Mainly bc I have it on hand but also I think it is a better design bc it is 21mm OD vs stock & BGM of 19mm. Also the DRT one uses a flywheel style star washer that I keep on hand vs a very specific conical washer. Note: The DRT comes with 2 washers, the star one for standard and the wavy for Cosa. Don't use both washers at the same time.
Torque: What are you guys torque the BGM style and DRT style to? Stock is 32 ft/lbs. I went to 45 ft/lbs for the BGM, but with incorrect washer install it is a moot point. Any thoughts on torque for the DRT style?
Loctite: Do any of you use loctite on the nut? I would probably go with blue 243 if I did anything, but if you use the correct washer you are probably good.
