Not yet
Not yet
The book just says remove mud flap. It's seems like all the work should be done on the right side but the fender seems to be attached behind the air box too.
It also referred to a bracket cover that doesn't look like anything I see.
Advice desired!!! Thank you
The pictures in the book don't look much like my unit
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
no need to remove
Not yet
Not yet
I should update. The pictures, numbers of screws and some small points were different. But I was able to follow the steps in the book and finally got the wheel off this morning. But fair warning to anyone else, if you are relying on the book to clearly lead you step by step, it won't.
[ Time: 0.0088s ][ Queries: 4 (0.0021s) ][ live ][ 343 ][ ThingOne ]
