Gts300ie 2018
Gts300ie 2018
Iv had to top my water up the other week?
Red watering can light,engine management light?
Reves up slightly on tickler?
Added water was ok.
Fantastic did kick in a couple of times.but the weather was in its high 30s at the time.
Now not used my bike for over a week.
Used it today. Engine management lights back on!..
So iv top abit more water in!! ABIT tomutch so iv let the back run with the water cap off!!
Now i have water pressure. And having bubbles pop up so often!!!
Have got head trubble??¿
2019 GTS 300 HPE w Malossi
PS, please edit you post so we can read it
@rallygeek avatar
@rallygeek avatar
Looks like a bot post
Thought it was a poem.
@rallygeek avatar
@rallygeek avatar
A poem bot !!
@genzmavera avatar
2027 Primavera 150 (Giorgio)
@genzmavera avatar
Bots have gotten so good now it's more common for them to use overly proper and articulate "flowery" grammar. Maybe his Midlands accent is seeping into the keyboard?
To answer the question - that "red watering can light" is the oil pressure light. It will be on any time the ignition is on, but the engine isn't running. If it's on with the engine running - STOP and do not start the engine again until the cause has been found, otherwise you'll destroy the engine PDQ.
As you asked the question in such a manner, I suggest you get it to a dealer if that red light comes on again with the engine running.
[ Time: 0.0072s ][ Queries: 3 (0.0016s) ][ live ][ 343 ][ ThingOne ]
