Posts: 1636 Location: Denver |
Hello fellow Vespa fans. I've spent the last two days with Google Gemini and a multimeter working on my friends 250. It's a 2006 w/ 3,800 miles. He went over railroad tracks and the scooter died. I've been through the kill switch, stator connector, coil lead in and out, negative ground, etc... Please look at the photo for the conclusion AI gave, and provide some input. There were no visible signs of breach in the harness, or even the slightest wiff of something burning. I'm not after witty, snarky answers from people with too much time on their hands looking for a fight. If you've been down this road, I'd appreciate your feedback. Thanks in advance!
Posts: 46296 Location: Pleasant Hill, CA |
Posts: 5488 Location: Veria, Greece |
Is the spark plug lead in its place?? On older models it was kind of short and they had the tendency to unplug from the coil over huge bumps…
Positive
SaFiS wrote: Is the spark plug lead in its place?? On older models it was kind of short and they had the tendency to unplug from the coil over huge bumps…
Positive
One of the first steps was spraying starter fluid. It's a no spark problem. I've been using a brand new cable and ngk cap through this. I have removed the coil and it is resting on the floorboard fully connected. I've been over every electrical connection numerous times. One of the early things I did was test the coil, lead, cap and plug with a 9V battery. A spark jumped.
2025 Vespa GTS300 Super Sport HPE2
Posts: 359 Location: Christchurch, New Zealand |
I had this issue on my 2009 GTS300. Everytime I went over a hard bump the scoot will give a hiccup. Replaced sparkplug, injector, cleaned throttle body, etc, but no success.
One day I went over a hard bump and it died totally. Turned out someone had replaced the screws that holds the seat hinge onto the body with slightly longer ones. Everytime the body under the hinge flexed from my weight on the seat this bolt pushed on the fuse under the hinge, cutting connection . Untill the day it pushed the fuse to far. So check this fuse.
Is that the 10 amp fuse going to the fuel pump? On the 250 it's on the side next to the relay. Thank you for the reply.
ok, I wanna say that I am not super familiar with Vespa electrical continuity, but...... i know that they can be finicky.
1. does the coil require a proper ground to the frame when mounted ?? 2. is it possible that the voltage regulator has ''popped'' inside breaking the cycle from the ecu thru the voltage regulator then to the coil to throw the lightning. is it even inline with what is needed to obtain spark? the 250's had weaker regulators. I've had 2 fry and melt my headlight with 17 volts. both of those had less than 5k miles of use. why did they crap out ? who knows... both stators were fine. 3. could the violent jarring of the railroad tracks shake loose the allowable tolerance of the tone ring for the security communication to the ECU. then it would never allow a start signal to be sent. would the security light activate during this ?? 4. both brake switches work properly ? they're kinda fragile and they have been known to malfunction. Im just trying to help ya shoot in the dark. you double confirmed that the kill switch works but the symptoms still say that it could be it. they can be sporatic. ⚠️ Last edited by Donttellmywife on UTC; edited 4 times
2019 GTS 300 HPE w Malossi
Posts: 9272 Location: Batmania aka Melbourne, Aus |
Abner_Bjorn wrote: the scooter died ⚠️ Last edited by SteelBytes on UTC; edited 3 times
Donttellmywife wrote: ok, I wanna say that I am not super familiar with Vespa electrical continuity, but...... i know that they can be finicky. 1. does the coil require a proper ground to the frame when mounted ?? |
SteelBytes wrote: do you hear the pump prime when turning on the ignition? do you hear the starter turn when pressing the start button? do the brake lights work? (check both) does the immo light go off with ign on? So now it's down to directly testing the o/p of the ECU with a suitable test LED - if that fails then it's deffo the ECU - which might even be behaving correctly for some unknown reason. If the LED works then it's an open circuit somewhere between the ECU o/p and the coil -ve terminal. |
Yep, I've beat this to death. AI is saying ECU. I have close to 20 hours w/ a multimeter into this. All the easy hanging fruit was eliminated. Keep the thoughts coming though. Thank you fellas.
Posts: 2137 Location: Tucson, AZ |
Read this thread:
DIY Diagnostic tool for injection Vespa's with MIU ECU Get a laptop and get IAWDiag. The KKL cable and Fiat adapter can be snagged off of Amazon cheaply. I'll find links if needed. On the GTS 250 and earlier 300s, the K-Line and L-Line on the Fiat adapter seem to be reversed (at least on the ones I've worked with), you may want to pull the insert out of the diagnostic plug on the scoot and plug the adapter in upside down. I'd use it to establish if the ECU is dead or not. If the cables and connections are good and you have the COM port adapter set right, it should report the ECU data back when you connect. There are a bunch of parameters you can enable and check, plus you can check for fault codes if the "left bank" coil is failing to fire. ⚠️ Last edited by az_slynch on UTC; edited 1 time
Those who think the ECU is in 'no start' mode are missing the point that it's been proven that the fuel pump primes OK on switch-on, there's +ve power to all the 'fuel loads' (coil, fuel pump and injector), and the ECU appears to work completely OK *except* for providing the correct signal for the coil. Note the coil itself has been proven OK.
Yes, the AI could be correct that the internal pull-down transistor feeding the coil in the ECU could be o/c, but instead the external connector could be corroded or the wire from the ECU to the coil could be broken. Those scenarios can be tested. The ECU itself can also be tested with a test LED on the o/p. |
Thank you Jim. I don't know what o/p and o/c mean.
Could you please elaborate on this some? " the external connector could be corroded or the wire from the ECU to the coil could be broken. Those scenarios can be tested. The ECU itself can also be tested with a test LED on the o/p." |
Abner_Bjorn wrote: Thank you Jim. I don't know what o/p and o/c mean. Could you please elaborate on this some? " the external connector could be corroded or the wire from the ECU to the coil could be broken. Those scenarios can be tested. The ECU itself can also be tested with a test LED on the o/p." |
How about this. I have another friend who has a 2007 GTS250 in good working order. He generously offered up the TB/ECU of his bike to try in the 2006. Getting it on and off is pretty straightforward. 1. How do I navigate the chipped key(s)? 2. Is this a good idea? Thank you in advance.
I would pull the glovebox and the antenna ring, letting it dangle. Hold his key near the ring, and use the scoot's key to switch the scoot on.
Ok, I've worked on this a bit more. I unhooked the harness going into the ECU. Key is off, negative battery terminal removed. Set my meter to ohms, clamped the black probe to the rear shock bolt. I came up with 7 ground pins on the connector. AI tells me it should only be 4. I've aborted the idea of swapping throttle bodies. I already have 1 non running 250 sitting here.
Abner_Bjorn wrote: How about this. I have another friend who has a 2007 GTS250 in good working order. He generously offered up the TB/ECU of his bike to try in the 2006. Getting it on and off is pretty straightforward. 1. How do I navigate the chipped key(s)? 2. Is this a good idea? Thank you in advance. It does entail both of you having Master keys. Swap his throttle body into your scoot, and swap the RFID chip from his Master key into yours. Try to start - if it does, you have a failed ECU. The best scenario is that it won't start (lack of spark with everything else, fuel pump etc working). Then you *know* it's an o/c (open circuit) bit of wiring between ECU o/p (output) and coil.
Positive
