So I have a cracked seat right below the butt, above the seat sensor. I bought myself a cover but didnt put it on in time. Now it is raining and the cracks are a bit wet. It is raining sideways, not directly on it. Is it possible the seat sensor goes in tilt because of the rain?
Not immediately, but probably best to put duct tape over the crack ASAP to prevent further water ingress
I tried duck tape, many types and it gets off in a week.
It looks like there is a lot of butt movement. Anyway, I bought a purpose sticker and I am planning to cover the whole section with it. Maybe it will help. |
Tspe and stickers are only (very) short term solutions.
Retrim or buy a seat are the only long term options. |
2007 MP3 250ie / 2022 MP3 500HPE SA [Bad Ass Edition]
Posts: 540 Location: CCS-Vzla |
sbaert wrote: Tspe and stickers are only (very) short term solutions. Retrim or buy a seat are the only long term options. As a very temporary solution, you can use thick plastic wrap with several layers, but it is only temporary, just to prevent water from entering. |
I have successfully repaired a motorcycle seat with Tear-Aid. It lasted for several years up and until the moment I installed a new cover on the seat.
I also use it for the above-ground pool and the tent's PVC groundsheet. Also very demanding repairs and it hardly ever fails. There are two types: one for vinyl and PVC, and another for other materials. You do need to use the right one. https://www.tear-aid.nl/en/ |
Not duck tape. It is called duct tape.
No need to start killing off the duck species. 🦆 |
Posts: 23502 Location: Harriman, Tennessee, Tn |
sbaert wrote: Not duck tape. It is called duct tape. No need to start killing off the duck species. 🦆 https://www.duckbrand.com/products/duck-tape |
Posts: 46369 Location: Pleasant Hill, CA |
old as dirt wrote: |
jimc wrote: And you're wrong - that's just one (and best avoided) brand of duct tape, and not known in much of the world. some describe it as 100 mile an hour tape as well. AI says this:Duck tape is a cloth- or polyethylene-backed pressure-sensitive tape, often reinforced with cotton mesh, originally named for the heavy cotton "duck" fabric used in its construction |
Origins and HistoryWorld War II invention: Developed in 1942 as a waterproof, hand-tearable sealing tape for ammunition boxes.The name: Named "duck tape" because it was made from cotton duck cloth and repelled water like a duck's back.Name shift: After the war, it was used to seal heating and air conditioning ducts and colored silver to match metalwork, leading to the common term "duct tape".
old as dirt wrote: Origins and HistoryWorld War II invention: Developed in 1942 as a waterproof, hand-tearable sealing tape for ammunition boxes.The name: Named "duck tape" because it was made from cotton duck cloth and repelled water like a duck's back.Name shift: After the war, it was used to seal heating and air conditioning ducts and colored silver to match metalwork, leading to the common term "duct tape". |
2025 Vespa GTS300 Super Sport HPE2
Posts: 412 Location: Christchurch, New Zealand |
