⚠️ Last edited by Salima Draghetta on UTC; edited 1 time
Re: Carrying extra fuel on/for GTS
Salima Draghetta wrote: Is this a prudent/imprudent idea? Those of you who ride long distances in the middle of nowhere with no gasoline stations along the way, do you simply avoid those situations and change your itineraries, or how do you carry any extra fuel for your Vespas? Thanks, Salima |
![]() UTC
Baart-less
Posts: 4499 Location: 56°58'34.49"N x 111°29'38.40"W |
A couple of people have replaced the battery cover screws with screw eyes.
![]() You can then use bungie cords to tie a one gallon gas can to the hump. ![]() Dave |
Olivia Newton-John
![]() p200, vbb, gt200, px150, vnb
Posts: 4494 Location: chippewa falls, wisconsin |
i take those hard plastic camping water bottles, fill them up, and toss them in my bag on the rear rack. one bottle will get you 60 miles or so.
![]() UTC
Baart-less
If it's not red and designed for gas it's not legal to fill and transport gas in. Will you get busted? Probably not....but after 56 years of being a contrarian I've learned to eliminate as many contentious and potentially problematic short cuts as possible.
Please use containers designed for fuel storage.! |
![]() UTC
GTS(me)/GTV(wife)
Posts: 1228 Location: Mill Valley, CA |
On my SF->LA ride along Hwy 1, I worried it might get a little dry between Carmel Valley and Cambria (I made it OK though). But just in case, I went to REI and got a camp fuel bottle. I made a funnel out of a small PVC bottle, and carried it in the pet carrier with my other stuff. I looked at the Nalgene bottles, but worried they might interact with the gas.
RIP
+1 MICHEAL MOORE. SALIMA you could get a couple of them and that's what they are used for so no worries on the getting busted. I used them backpacking and think they would travel better than the red gas containers. No chance of accidentally getting a hole in one of them like the red ones. They also handle heat better than plastic. Plastic tends to get softer if it's hot and they sit in the sun. Metal's much better. Sounds like a great trip
![]() 21 75th Anniv. Primavera, 10 GTS Super 300, 64 Allstate, 61 VNB, 61 GL, 61 Lammy LI 125 Mahi Shriner, 57 Lammy LD125
Posts: 1410 Location: Baltimore-Washington-Asbury Park at the Jersey Shore |
Brilliant solution, Chetwynder!
On the Cannonball last year, most of us carried an extra gas can with bungee cords. The longest we had to run between stations was 110 miles though. I think that was in eastern Oregon. You will probably end up finding a station along the way but the extra gallon is well worth the peace of mind. Also someone mentioned a while back that it is not good to get too low because the gauge (or something else, I forget) is cooled by the gas. |
![]() UTC
Baart-less
Bobovespa wrote: Also someone mentioned a while back that it is not good to get too low because the gauge (or something else, I forget) is cooled by the gas. Dave |
I just use a red plastic gas container with a bungee like others here. Works just fine.
I also bought a camp fuel bottle, but I haven't used it on a trip yet. If you want to fill these up, make sure you bring a funnel. I looked into auxiliary tanks at one time, but I found them to be a very expensive way to solve a very simple problem. ![]() This is a two gallon container. I've since purchased a smaller one.
from poster and mileage junkie Mike Lynch:
2004 GT-200 "Auxiliary Fuel Tank". 2004 GT-200 "Auxiliary Fuel Tank" - Part two. |
![]() UTC
Baart-less
The problem with adding an auxiliary tank on a GTS is the location of the fuel pump. Because the pump resides in the fuel tank you have to some how get the fuel into the tank, you cannot simply tap in to a fuel line as you would on a carburetor equipped bike like the GT.
Dave |
+1 for the eye hole screws. I think I may have been a pioneer in that field.
Here's my bike halfway through a saddlesore 1000 ride. ![]() |
The problem with carrying extra gas is when you park your scoot and some asshat decides to torch your bike. I like the REI bottle because it's something you can possibly store under the seat or carry in a bag and walk with. Personally, I wouldn't leave a scoot unattended with gas strapped to it.
spock wrote: The problem with carrying extra gas is when you park your scoot and some asshat decides to torch your bike. I like the REI bottle because it's something you can possibly store under the seat or carry in a bag and walk with. Personally, I wouldn't leave a scoot unattended with gas strapped to it. Save $5 less than REI.. http://cgi.ebay.com/MSR-33-oz-Fuel-Bottle-New_W0QQitemZ300152590223QQihZ020QQcategoryZ87136QQcmdZViewItem |
plastic container - no problem
I carried a plastic 1 gallon container in the pet carrier on a long distance trip last summer. (Also carried a funnel.) Air temperatures were easily over 90 degrees; don't know how hot the engine got. Never had a problem with the plastic container. Never needed the extra fuel, either. But. like Bobo said, it's well worth the peace of mind. It also gave me the opportunity to help out a motorcyclist. Creating good scooter karma and goodwill with a biker - can't beat that.
Salima Draghetta wrote: How prudent/imprudent would it be to carry extra fuel (let's say in a small metal REI-type container, for sake of conversation here) under the seat in the storage space there? It gets really hot under there, and if the fuel is in a metal container, (let's say enough containers for about 1 gallon extra fuel) is that not a possible formula for trouble if under the seat? I understand the issues connected with a red plastic container full of fuel in full view attached to the Vespa floor, but my intuition would tell me (correct me if I am wrong) that temps there would not rise as high as in saddle bags or under the seat? Thanks, Salima http://www.grainger.com/Grainger/items/2AX29 Trigger mechanism enables the pouring of small quantities of liquid. Leaktight, self-closing cap prevents spillage and automatically vents to guard against explosion. Dual-density flame arrester protects against external heat sources. Justrite's unique design includes a current-carrying carbon insert imbedded into the can for proper grounding. |
Some duplication, but here you go:
http://www.nyscooterclub.com/forum/viewtopic.php?f=3&t=3166 |
Salima Draghetta wrote: How prudent/imprudent would it be to carry extra fuel (let's say in a small metal REI-type container, for sake of conversation here) under the seat in the storage space there? It gets really hot under there, and if the fuel is in a metal container, (let's say enough containers for about 1 gallon extra fuel) is that not a possible formula for trouble if under the seat? I understand the issues connected with a red plastic container full of fuel in full view attached to the Vespa floor, but my intuition would tell me (correct me if I am wrong) that temps there would not rise as high as in saddle bags or under the seat? Thanks, Salima Where's your gas tank located? |
![]() UTC
"Jefe"
Posts: 859 Location: Vespa Club Los Gatos - San Jose CA |
Bobovespa wrote: Brilliant solution, Chetwynder! On the Cannonball last year, most of us carried an extra gas can with bungee cords. The longest we had to run between stations was 110 miles though. I think that was in eastern Oregon. You will probably end up finding a station along the way but the extra gallon is well worth the peace of mind. Also someone mentioned a while back that it is not good to get too low because the gauge (or something else, I forget) is cooled by the gas. You forgot to mention that a few of us JD, Styrax, and myself were outfitted with auxiliary tanks mounted on the back rack. It worked for my ET once I figured the optimum time to start using the the auxiliary tank. |
Spock if you lived on the east coast you would be too young to even remember Pintos ... they are all rusted and gone ... even the ones that did not go boom.
And Mike, I know you guys had amazing fuel rigs for the Cannonball. I left that part out cuz people were looking for simple temporary solutions. Yours was definitely bigger! |
![]() UTC
"Jefe"
Bobovespa wrote: Spock if you lived on the east coast you would be too young to even remember Pintos ... they are all rusted and gone ... even the ones that did not go boom. And Mike, I know you guys had amazing fuel rigs for the Cannonball. I left that part out cuz people were looking for simple temporary solutions. Yours was definitely bigger! |
EXTRA GAS
I ran out of gas one time. If I remember right the last bar on the gas gauge when it starts flashing means you have less then 30 miles left. In the Dakotas last September I used my extra gas can twice.
eye-hole screws
post deleted by Salima
![]() UTC
Posts: 4332 Location: Utah Valley |
RIP
![]() 29,000 miles on my atlantic pastel green 2007 GTS 250
Late to the thread, but not too late to the task...I kept a regular .5L plasitc water bottle filled with gasoline, in my pet carrier, for probably three, four months, with never a problem. Just to be prudent, I recently replaced it with an aluminum bottle from REI. That, of course, is even safer (but the water bottle was better to pour into the tank).
I tested the gas gauge on my GTS and posted about it. IIRC, two bars meant 24 miles till no bars, and from there it were another 40 miles or so until empty. Not sure if any of this is helpful. Quantities are just too small, for long distance rides through no-gas-station territories. |
![]() UTC
RIP
Salima,
If I had planned a trip into "uncharted territories", so-to-speak, I would also want more fuel. I think BurgerBob's solution below is tried and trusted. If you search for his contributions, you can find some other helpful suggestions too. One interesting thread of his is this: My recent trip pics |
Yet another option...
These are used on small boats. It's a flexible nitrile fuel bag. It would probably fit in the pet carrier and it's rated for 6 gallons, but you could put in 2-3.
http://www.imtra.com/product/pumps_tanks/nauta_holding_tanks/portable_outboard_tanks/portable_outboard_tanks/fb521100.htm Description: Portable Outboard Tank Maximum Capacity: 6 gal (25 liter) Dimensions: 16.5 x 9 x 10" (42 x 23 x 25cm) Tank Material: Nitrile Warranty: 1 year Included Fittings: FTP610; FTP700 Spanner Wrench: Included (FTP010) Weight: 4.000 lbs. ![]() |
Sir Frets-A-Lot
![]() Vespa GT250ie/L, Honda Ruckus 50, Honda NT700V, Honda CB125
Posts: 11197 Location: Bee eff eee. |
The thing to worry about in general with extra fuel over just a few oz. is sloshing.
I know I'm looking at an extra fuel tank (for no reason heh), and for stability's sake I'm gonna get the kind with foam in it to help prevent that sort of nonsense. |
