ET4
ET4
Hi all, first post for me. I've searched the forum but haven't found a simple answer to my simple question. How do I change the headlight bulb on an ET4?
I've taken the trim ring off the headlight. What's next? I thought the headlight would pull out. What's next?
Thanks all,
Jacqui
@jonnycat avatar
2003 ET2 Dragon Red (Sold), 2003 ET4 - Giada
@jonnycat avatar
Hi Jacqui, I wish it was that simple...
You have to remove the front cowl assembly to access to the back of the lamp fitting for the bulb(s)...which means removing the front horn cast and badge, both mirrors, and the 3 screws the hold it all together. Once you've done that you can detach the cowl and see the connectors for the bulb.
Download the ET4 workshop manual in the TECH LIBRARY (link below); go to page 8-1 (BODYWORK) for diagrams.
Should you attempt this, be careful not to touch the glass of the new bulb. Fingerprints leave an oil and create a hotspot that causes the glass to break after some time. You can wipe it clean with rubbing alcohol should you touch it.
[topic630]
@genie avatar
Gobshite Shiva
Gobshite Shiva
@genie avatar
hi, and welcome to MV! as jonnycat says, it's not nearly as simple as it looks like it should be except - unless something has changed between leader and pre-leader ET4s - i didn't have to take off the badge and horncast, just the front of the handlebar cover.
anyway, i'll tell you how i did it. ....
mirrors off first - the two sides have different fittings, one just screws off, the other has a bolt.
handlebar cover off - two screws at the back, and one at the front. be careful with the front screw - there's one just below the headlight that looks as thought it should be for the handlebar cover, but it's not, that one adjusts the aim for the headlight. the third screw for the handlebar cover is below this, in a stupidly inaccessible location. it's easier to get at if you turn the handlebars all the way to one side - and make sure you're using a magnetic tipped screwdriver otherwise the screw will escape and vanish into the body.
once the screws are off there are a couple of little plastic tabs at the end of the handlebar cover, these need pressing in to release it. once those are released the whole thing should come away, revealing the headlight assembly. the bulbholder comes out by twisting anti-clockwise, it should just pop out. bulb comes out by twisting in the same direction.
just reverse the above instructions to put it all back together. there are tabs here and there on the front handlebar cover that need to slide underneath the back part of the cover - make sure they're all underneath before you screw it back together.
ET4
ET4
Wow, that sounds fun! Thanks for the detailed replies - very helpful. Genie, can I ask how long it took you? Am wondering how much of my weekend I am going to lose on this!!
@genie avatar
Gobshite Shiva
Gobshite Shiva
@genie avatar
it sounds a lot more complicated than it actually is - the most annoying part is getting the mirrors back on. start to finish it took me about 25 minutes.
@jonnycat avatar
@jonnycat avatar
Hi Genie, you might want to help gnulover install the Stebel too!
btw, how's yours coming along? Will it then be Loud Ugly Betty?
@genie avatar
Gobshite Shiva
Gobshite Shiva
@genie avatar
haven't even bought the horns yet i'm waiting for it to warm up a bit as i've got no indoor space to work, and circulation problems in my hands make it difficult to work outdoors without thick gloves on until the temperature reaches about 55F.
then - watch out!! bawling betty and wailing wilma will be scaring pedestrians and dopey cagers out of their underpants
@at_rider avatar
2002 ET4
@at_rider avatar
2002 ET4
Not to revive old threads but, if you're facing the front of the scooter, how do you get the right mirror off?
I've loosed the top nut and started turning the whole mirror counterclockwise to loosen it up but now notice that there is a nut the bolt is threaded to underneath that is just rotating along as I turn that needs to be held in place in order to pull the section out.
Am I doing this wrong? I can't seem to get in there with a wrench to hold the nut without stretching the cowl apart and even then it's pretty tough. Doesn't seem right that you would have to go through all this.
@at_rider avatar
2002 ET4
@at_rider avatar
2002 ET4
Nevermind! Got it. I was thinking one-dimensionally...
ET4
ET4
Thanks for the tips
I just changed out the bulb on my ET4, and it was a snap thanks to Genie's advice. I'm glad I checked out this forum, because unlike changing the headlight in most cars, this one wasn't obvious. I suppose I would've figured it out via trial and error, but you saved me a lot of time.
I'd like to take a moment to offer you props for a real nice BBS. It just seems this board has a real positive, helpful vibe to it vs. Scooterist BBS. It seems if you go over there with a question, unless it's a real tough one, you'll always get one or more people who will come back at you with a 'hey dummy, if you were a real scooterist, you'd know how to do that' type of post. Hey, everyone was a noob once, even those guys on the other BBS.
Anyway, thanks for a real helpful BBS. You guys are a great resource. Please keep up the postitive vibe and the good work!
Harumph...
This isn't a BBS (private bulletin boards are extremely few these days now the Internet is here).
This isn't UseNet either. Be thankful for that in some ways...
It's a web-forum. there are pros and cons about the medium, but as the genre goes, yes, this is a good one.
[ Time: 0.0104s ][ Queries: 3 (0.0041s) ][ live ][ 343 ][ ThingOne ]
