Mon Jan 28, 2008 11:47 am
(GT200L) ... no more scoot :o(
Mon Jan 28, 2008 11:47 am linkquote
Since Max at Motorsport Scooters didn't have any in stock, I decided to take some measurements from my GT200, and make a clutch holding tool.
Here is the drawing I made.
Done in SolidWorks.
Mon Jan 28, 2008 11:50 am
Mon Jan 28, 2008 11:50 am linkquote
I went into Home Depot to get a couple of hex bolts, and a large washer.
They didn't have a large enough washer, so I asked one of the guys if they had something that would possibly work.
He took me to the construction supplies area, and had a square shaped washer for doing concrete, or possibly chain link fencing.
The inside diameter was too small (7/8" and I needed 1 3/8") so I had the guy in our model shop at work bore out the hole.
I drilled and tapped the two threaded holes, assembled the bolts in place, and trimmed the bolt heads to the right length.
The finished tool.
Voila!
Washer and bolts
Mon Jan 28, 2008 11:55 am
Mon Jan 28, 2008 11:55 am linkquote
So far it has worked fine.
I need to get the variator holding tool to finish the belt replacement.
I was shipped the one for the GTS, not the GT.
Mon Jan 28, 2008 12:01 pm
GTS 250
GTS 250
Mon Jan 28, 2008 12:01 pm linkquote
post deleted by Salima
Last edited by Salima Draghetta on Sat Jan 12, 2013 10:51 pm; edited 1 time in total
Mon Jan 28, 2008 4:07 pm
2007 Plum GT "Stephanie"
Mon Jan 28, 2008 4:07 pm linkquote
tool
Nice job on the tool----sure is handy to have a nicely equipped shop.
Mon Jan 28, 2008 4:51 pm
Mon Jan 28, 2008 4:51 pm linkquote
Now THAT'S what I'm talkin' about!!
http://www.modernvespa.com/forum/viewtopic.php?t=18578&highlight=machinists
Tue Jan 29, 2008 2:13 am
Vespa GTS 300 SUPER
Vespa GTS 300 SUPER
Tue Jan 29, 2008 2:13 am linkquote
Re: GT200 / GTS 250 Clutch Holding Tool.
great job!
is it possible have measurements in cm or mm?!
tks!
Tue Jan 29, 2008 8:29 am
Tue Jan 29, 2008 8:29 am linkquote
great job!
tks!
Sure.
I should have thought to dual dimension since this is the world wide web.
Here you go.
In mm
  DoubleGood Vespa T-Shirts
[ Time: 0.0793s ][ Queries: 35 (0.0517s) ][ Debug on ][ 156 ][ Thing Two ]
