LX125
LX125
Hi guys,
i just bought my LX 125 and bought a tomtom rider 2nd edition but i dunno how to attached it? Do you have any suggestions? Thanks!!
@morvran avatar
2008 GTSie and 1986 T5
@morvran avatar
I attached it to the metal support on my windscreen, using the supplied attachments. If you don't have a windscreen, I'll have to go look at mine later to see how else I would have done it. If you do have one, I'll try to take a pic to show you how I did mine.
@progetto_300 avatar
2010 GTS 300 SUPER
2010 GTS 300 SUPER
I use the "sucktion cup device" and a selfmade security cord.
Works perfect, never fell off yet not even on bad roads.
I still have to find a way to get some electricity.
LX125
LX125
Hi,
Thanks for the reply!! what brilliant ideas you guys have!
unfortunately i dun have a windscreen so i tried attaching it to the left mirror. it looks fine but im not sure its a good idea.
Thanks heaps!
@morvran avatar
@morvran avatar
The mirror may work, and I'd like that option as it would keep the screen up higher on the bike (so you don't have to look down too far), but it's possible it would eventually start to swing the mirror arm around.
@papa_smurf avatar
GTS250ie, ET4
@papa_smurf avatar
GTS250ie, ET4
So is that the suction cup mounting that came with the TomTom?
@michael_h avatar
2006 LX150 "Amadora"
@michael_h avatar
You can try using a RAM mount. http://www.ram-mount.com/.
@mandarinia avatar
LX150
@mandarinia avatar
LX150
I think the problem with the RAM Mounts is that it requires a tubular mounting point. External inline image provided by member with no explanatory text
With Vespa's finished head fascia, it's difficult to find a suitable place to put the Ram mount without some surgery.
@michael_h avatar
@michael_h avatar
Agree that it is a permanent solution, but RAM does make mounting units that can be fixed to a flat surface. Might work on the top surface of the glovebox.
Michael
@morvran avatar
@morvran avatar
It comes with RAM mounts actually...I'd have to look and see how many kinds again, but I remember there being multiple options. I used the tubular RAM mount that came with the Rider2.
@kevin avatar
2005 GT200
@kevin avatar
2005 GT200
I'm not one of the "search before posting!" types (don't mind at all, in fact), but I just thought I'd point out that there have been quite a few really informative threads on this subject.
Run searches on terms like "TomTom", "GPS" and "sat nav". There's some great info and good ideas here.
Kevin
@mandarinia avatar
LX150
@mandarinia avatar
LX150
Kevin
Yep, I was going to mention that as well. I don't mind repeat questions if they bring a new dimension to the topic. But lots of valuable stuff is already out there.
That being said...I did some digging, and I *really* like Jess's solution.
(hey...is that supposed to be "Jess' solution," or "Jess's solution..." technically speaking? And are the ellipses supposed to come after the quote, or before??)
Anyway...check out his mount...with pictures...
https://modernvespa.com/forum/topic411
And I *really* *really* like his solution to power...
https://modernvespa.com/forum/topic13067
Very clean!
The only thing I'd add is that personally, am not a fan of tap splices. If you're going to tap an existing wire like the one in the horn cover shown in Dan's writeup, (LX150: Wiring up a Zumo 550 GPS)
example:
personally I think a long term solution that is easier to troubleshoot would be to put in a legitimate power connector from radio shack:
Spliced connections inevitably corrode, and if the wire gauge is small, you'll find yourself with intermittent power issues to try to decipher much sooner with a splice solution than with a proper quick disconnect terminal.
[/img]
@ken_photo avatar
'07 Vespa GTS250ie
@ken_photo avatar
'07 Vespa GTS250ie
I use the ram mounts that come with it and have it attached to my mirror stem on my GTS.
2010 GTS 300 SUPER
2010 GTS 300 SUPER
Yep!
[ Time: 0.0226s ][ Queries: 5 (0.0118s) ][ live ][ 313 ][ ThingOne ]
