Upcoming Server Maintenance
Modern Vespa will be down for approximately 1 hour on Sunday, December 4th, starting at 9pm Pacific Standard Time
Fri, 14 Mar 2008 21:32:50 +0000
Vespa GTS 250
Vespa GTS 250
Fri, 14 Mar 2008 21:32:50 +0000 linkquote
I went for a nice long ride (about 50 miles), and after I got back, turned off the engine, and parked in the garage, I started hearing this kind of farting/burping sound. It happened about every 15-20 seconds or so. It was coming from the engine compartment but when I removed the pet carrier I couldn't tell where exactly it was. It didn't sound like the fan at all. What's up? Does it need Rolaids?
Fri, 14 Mar 2008 21:45:22 +0000
Rock Star
Moto Guzzi V7 Classic
Rock Star
Fri, 14 Mar 2008 21:45:22 +0000 linkquote
Mine used to do that when it was brand new (GTV here). But after 400-500miles or so, it stopped doing it. Yeah, it was weird. It was more like mini-burps, like heartburn.
Fri, 14 Mar 2008 21:47:57 +0000
'07 LX150 (Dragon Red), '06 GTS250ie (Black)
Fri, 14 Mar 2008 21:47:57 +0000 linkquote
mine used to do that too... there's some explination but i can't remember what,
Fri, 14 Mar 2008 21:56:08 +0000
2009 GTV 250
2009 GTV 250
Fri, 14 Mar 2008 21:56:08 +0000 linkquote
Gas tank pressure....just remove the gas cap for a second or 2. Has something to do with the gas evaporator system or something like that....I'm sure someone else really knows.
Can this system be removed?
Fri, 14 Mar 2008 22:15:58 +0000
Avio Grey '07 GTV250
Fri, 14 Mar 2008 22:15:58 +0000 linkquote
Mine does it too. The best fix is to just drop some Beano in the tank.
Fri, 14 Mar 2008 22:31:11 +0000
Fri, 14 Mar 2008 22:31:11 +0000 linkquote
I've never heard that from my GTS.
Fri, 14 Mar 2008 22:36:25 +0000
GT60
GT60
Fri, 14 Mar 2008 22:36:25 +0000 linkquote
This has actually been discussed quite a bit. There are a couple of threads with pictures, but on this thread Jess gives a quick description of removal.
http://www.modernvespa.com/forum/viewtopic.php?t=15376&highlight=evap
Sometimes a check valve doesn't work quite right. I think the noise is normal, though.
Fri, 14 Mar 2008 23:44:13 +0000
Kitted ET4.
Kitted ET4.
Fri, 14 Mar 2008 23:44:13 +0000 linkquote
Cheap Gas = Indigestion?
That's bizarre....
Sat, 15 Mar 2008 00:01:40 +0000
GTS 250 TWO-TONE/GT60(#993)
Sat, 15 Mar 2008 00:01:40 +0000 linkquote
Decompression of the fuel injection system. Nothing to worry about at all. Very normal.
Sat, 15 Mar 2008 00:04:34 +0000
Vespa GTS 250
Vespa GTS 250
Sat, 15 Mar 2008 00:04:34 +0000 linkquote
Thanks. Sounds like enough people have had the same thing happen that it's nothing to worry about, unless I start to have a stumble problems. In that case I guess I refer back to this thread above and disable the evap system as Jess describes. I've never noticed any stumbles (had it up to 80mph today testing my new flyscreen!).
Ed
Sat, 15 Mar 2008 01:53:29 +0000
Vespa GTS
Vespa GTS
Sat, 15 Mar 2008 01:53:29 +0000 linkquote
I think I've isolated the source. It does involve the pet carrier after all.
http://www.youtube.com/watch?v=ZP-n3E43M3Y
[ Time: 0.0255s ][ Queries: 4 (0.0065s) ][ Debug on ][ 237 ][ Thing Two ]
