Preparation:
Take off the Piaggio badge and the front cover as detailed in the owner's manual for changing headlight bulbs.
Then take off the grey spoiler panel beneath the windscreen (5 screws).
Remove the foot panel rubber under your left foot and undo the small screws that hold the underfairing. There are another couple of screws behind the left front mudguard (on the floorboard fairing) to remove, to allow you to get at the original horn.
You don't have to take the fairing that covers the original horn off, you just have to manoeuver and bend it back a bit so that you can get at the horn.
Install:
Remove the original horn and in its place substitute the relay plugging the original horn connectors onto terminals 85 and 86 of the relay.
Connect a fused feed from the battery and feed it down to the relay and connect it to terminal 30. Feed another wire up to the windscreen area securing it tightly and avoiding the front suspension, connecting it to terminal 87. This is the wiring done.
Now for the compact. Get a hacksaw and cut off the original mounting block that is attached to the body of the horn. This gets in the way and needs removal.
The horn is mounted silver cylindrical body of the horn upwards, lying horizontally with the terminals pointing to the left, when looking from the front of the scooter. The black plastic horn opening will be facing in towards the suspension area of the scooter - the sound of the horn will reflect out when it is honked.
I suggest you stick some double sided foam tape to the bits of the horn which make contact with the scooter to stop it vibrating. I stuck one bit along the silver body of the horn where it makes contact with the underside of the speedo unit and another bit on the round "mushroom" shaped area of the horn where it makes contact with the rear side of the gray plastic under-windshield spoiler. Connect the negative terminal of the horn to the frame and the positive to the relay feed 87 which you have just routed. Manoeuver the horn into place and cable tie it to the body coloured cross brace that runs across the front fairing.
Secure the relay in place of the original horn with a cable tie and replace all the fairing screws.
Replace the front spoiler, windshield and fairing and you're done...
The most difficult bit of this install is getting at the original horn as the space under the fairing is really tight, but take your time and you'll be fine. Routing the feed fron the battery positive isn't too hard just make sure you cable tie as you go along. Having self adhesive cable ties helps when going along under the footboard helps. They also help with the routing form the relay up to the horn as you don't want that feed fouling the suspension parallellogram!
⚠️ Last edited by DougL on UTC; edited 1 time
