@shag avatar
2007 GTS250, 2014 GTS 300 Super, 2009 Harley Crossbones, 883 Super Low Harley, 2010 LX150
@shag avatar
It seems that the auto cut off on most gas pumps doesn't work when filling my scooter (Vespa LX 150). I hold the handle release so the minimal flow comes through the hose but 3 out of 2 times I get a little overflow and have to wipe the area around the tank down, sometimes even running down the side........which scares the shit out of me knowing the hot exhaust pipe is underneth.
I could try to not fill it up all the way but it's hard to know how full it is.
Any Suggestions?
@beale avatar
None! I sold it :(
@beale avatar
None! I sold it :(
Not overfilling tank?
on the Gt I have done the overfill also. What I started doing is this. Ride unti the low fuel light is good an solid lit watch the gas pump until you have right at 1.8 gal. Stop and look in tank, fill very slowly until you see gas getting close. seems to work for me, Beale.
@gliderguynj avatar
Vespa LX150
@gliderguynj avatar
Vespa LX150
I overflowed my first tankfull on the LX150. Basically now I go by the guage and the warning light. I can get about 100 miles plus or minus a few until the fuel warning light starts to flicker. It will then usually take 1.5 +/- to fill. At the pump I fill the first gallon without worry. I then just fill a 10th or less and look until it's topped off. I don't fill it to the point that it will enter the neck.
It's not an easy tank to fill, but once you've done a few you just deal with it.
Doug
@dixiecrat avatar
LX 150
@dixiecrat avatar
LX 150
tank filling
This has worked for me. Stick the nozzel into the tank neck as deeply as it will go. Put it on a slow rate of fill. The auto cut off will work ok and becaue the nozzel is in deep, there is no overflow. I never paid much attention to how much is added or how many miles to a tank.
It may not be the optimum fill with the maximum in the tank, but it sure beats dumping about a quart into the under seat storage bucket (like I did the first time.)
@xman avatar
gt200
@xman avatar
gt200
I've post this in another thread, so I hope this helps you.
"I've spilt a little gas a few times and witness a friend totally over flow his tank and got it over everything...ouch.
I have a system which takes a little longer, but has help me keep from spillage.
1) turn the engine off and keep the headlights on
2) take the trunk out and prop up the seat with it so you can see the dash board
3) with the dash on you can monitor the gas levels
3) you can pump away full speed till about half tank, then slow down and watch it catch up. At this point it's up to you how full you want it. But you must ease it in with short burst.
4) last time I fill it to the needle hit the top, it was about 2 gal exactly."
X
P.s. I guess it should be mention that I run my tank down as low as it goes usually.
⚠️ Last edited by xman on UTC; edited 1 time
@ataritron avatar
GT200
@ataritron avatar
GT200
The solution is simple. always fill the scooter when the needle is near the bottom mark on the gas gage and watch the gas meter as you fill up and stop it just before 2 gallons, I have never went over since I started this practice.
@nukie avatar
GTS250 "Atomic Blast", GT200 Blue and White "Alfie", SQREAM Scooter Club
@nukie avatar
I know when I hit my low fuel light that the tank takes about 1.7 gallons. So I just watch the pump and cut it off around there. I have also found that some automatic pumps do work OK with my gas tank and others do not. You might shop around for a station that has pumps that will cut off without overflowing.
@spock avatar
2002 ET4 & 1980 100 Sport
@spock avatar
My answer to overflowing is a paper towel. Gas evaporates fast, I mean really fast. Even if it hits a hot pipe down there. You won't burn, trust me. I remember my old piece of crap VW Super Beetle. The carb boiled over constantly, spitting gas on a hot engine block, and I'll be dammed if the thing didn't catch fire! I would have made all my money back on that thing if it just caught fire and burned in the parking lot!
Anyway, you'll learn to catch it before it tops off one day. In the meantime, the towel.
@xman avatar
gt200
@xman avatar
gt200
LOL... spock drives a VW...it's not logical.
X
@spock avatar
@spock avatar
I junked that piece of crap a long time ago. Apparently, a 1971 super beetle is probably the worst model they ever made. My four wheeler of choice now is a Subaru Forester. The Baja is a little lame looking, but that may be my next Subaru. It'll be a turbo of course.
@grant avatar
"Between Scooters"
@grant avatar
"Between Scooters"
This was my number 1 complaint with my GT until someone explained to me how you are supposed to do it. Since then, I haven't overflowed even once.
1) Make sure that the side of the scooter (right vs left) that has the cap is closest to the pump.
2) Insert nozzle *all* the way down as far as it will go into the tank.
3) Fill away and the pump should shut off before any overflowage
** to be safe I always have a few paper towels around the nozzle near the tank just in case.
This seems so simple, yet I wasn't doing it right for the longest time.
@christine avatar
Vespa GT200
@christine avatar
Vespa GT200
Even being very careful you can sometimes get a bad pump. I had one "cough" well before the tank was full. This spirted up the filler neck and ended up messing up my GT emission control EVAP line (hopefully temporarily).
I have one station where I've had no problem - I'm going to stick with it.
@vespagt avatar
@vespagt avatar
i was told about this and haven't had any problems either. try it.
@monkmonk avatar
@monkmonk avatar
I've got to agree with Christine here, some pumps are just crap.
I've had good luck at Costco and the gas station around the corner. But bad luck at the two Chevrons that I've tried to stop at. Even when I shoved the nozzle all the way in the Chevron pumps spilled gas all over.
MM
@bobthebuilder avatar
05 GT200 Black
05 GT200 Black
I tend to follow the method of filling up just after the fuel light stops flashing and stays on. I find I can get 7.5 litres (Aussie litres right at that point and be safe OR if I have another 1 way trip to work I can get 8 litres in. Not sure what that equates to in US Gal but you get the idea.
Also, I have a little L.E.D. torch that I use in one hand and the fuel pump in the other and carefully watch the level come up after I have filled it about 3/4 of the way. Must look really funny to those around...
This is after over-filling it about 5 times
Cheers,
Bob
@giuliano avatar
Piaggio X9 "Lexx"
@giuliano avatar
Piaggio X9 "Lexx"
I have had terrible overflowing problems since I got my GT125 - but I think I have found a solution.
The cut off works by the rising fuel blocking a small air tube at the bottom of the fuel nozzle, and is designed to work with the nozzle pushed down a car filler opening.
Now, I have noticed the fuel filler on my bike (and I assume other GTs are the same) slopes from the front to the back of the machine (and not fro mthe side like a car would). That means if I fill from the side of the bike, as would otherwise seem natural, the small hole at the end of the pump nozzle will not fill with fuel and cut off properly.
If I turn the fuel pump handle so that the hose points towards the back of the machine, ie, at the same angle as the filler opening, it cuts off as it should becasue when the fuel rises the air hole is hit by the rising fuel at an earlier point in filling. I don't pump full speed, but I don't have to pump super slow either.
Try it - it seems more simple than the alternative solutions posted here and seems to work for me.
@jrsjr avatar
Nazgul
@jrsjr avatar
Nazgul
I had a bunch of problems filling my GT so I adopted this method.
1) Insert nozzle *all* the way down as far as it will go into the tank. If it doesn't fit right, go to another gas station.
2) Pump the gas S-L-O-W-L-Y.
3) Don't even *think* about topping off once the pump's auto-shutoff stops the flow of fuel the first time.
I haven't had any problems since I started doing it this way.
@grind avatar
@grind avatar
I do that with my cars, and I've seen my fuel economy improve.
@xman avatar
gt200
@xman avatar
gt200
Hmm...I wonder why that is? I always try to fill it up as much as possible, but would change if it would improve my MPG.
X
@grind avatar
@grind avatar
My assumption is that the nozzle's vapor recovery system is catching a bit of 'burp' each time you squeeze 'til it clicks. The delivery system counts this 'burp', but it doesn't actually go into your tank.
Again, that's only my assumption, not based on fact, other than my fuel economy did improve about 1 mpg when I stopped 'topping it off'.
@jerryg avatar
2005 Dragon Red Vespa ET4 Speedster
@jerryg avatar
This is exactly what I do. No matter what the urge is, just remove the nozzle as soon as it stops. There seems to be gas in the nozzle that flows into the tank as you lift it. Maybe 3 - 4 ounces.
[ Time: 0.0353s ][ Queries: 3 (0.0077s) ][ Debug on ][ 309 ][ Thing One ]
