I had previously heard about
Northern Tool having their air horns on sale for $29.95 - it is roughly the size of the Stebel Nautilus (which I have on my V-Strom) and supposedly made by Stebel (not verified however).
Wolo Bad Boy
I got one for future projects. I tested it along with mine and the wife said it was OK to install on her new MP3 500.
So, I read thru the
good information above (thanks all!) and started pulling tupperware off of the 2-week old scoot. Of course, I waited until after the first service.
First, I used Lex's side cover removal - 4 screws for the undercowl piece, 6 screws for each side piece. I use a 15-compartment box to organize the screws as they come off.
My wife had already lost the leftside "corner" screw that Lex shows in his photo as "cosmetic only". I noticed that the right side was loose and wouldn't tighten. With the panel off, I tightened the nut and added a drop of locktite to keep it that way.
I also removed the front "windscreen" panel, assisted by seldom's instructions - 4 screws (3 long and 1 short ???) plus a screw under the pop-off Piaggio emblem. This uncovers the four relays and their sockets:
One good thing is that there is plenty of room under the front to add stuff. I poked around, reread the suggestions here, and decided on a plan. As mentioned, I didn't want the air horn operational unless the motor was running, plus I didn't want to have to run additional +12 volt wires from the battery when we added stuff later, So, I decided to route the positive via 12 gauge wire thru a relay controlled by the headlight relay output to a small fuse panel on the left side front (I intended to mount the horn on the right side).
When I went to Napa to pick up some Posi-taps, I found this small fuse box for about $16:
I typically use a Blue Sea 5025 but this is smaller (and cheaper!) and looks like it will fit the bill.
It looked like the biggest pain was running the 12 gauge wire from the battery up into the cowl area. Of course, just the wire would not route on its own and the rifle bore cleaning rod was too thick, so a regular coat hanger was enlisted to pull the wire through.
Here I opened the two lower rightside hatches to run the "puller" from the left and drag the wire from right-to-left:
I then ran the puller from the top next to the battery to pull the wire up from the bottom. At the battery, I spliced in a fuse holder (best for protecting the long wire run forward) and a ring crimp connector. The fuse holder will house a 30 amp fuse. I left this unconnected for now.
Finally, I estimated and cut the wire and fed it up thru the tunnel into the cowl area. I finally had something to tie-wrap to, so that was done to route the wire up into the 4-relay area.
As per Lex's discussion, I was planning to use two relays - one to power the new aux fuse box and the other to power the new horn. The horn relay came with the horn, so I acquired a Bosch 12-volt relay for the other.
I didn't take an interim picture but I mounted the two relays on the square frame supports near the bank of 4 relays. Here is the result after wiring:
I looked at Lex's relay map and it didn't match mine. All the relays are exactly the same, so the order really doesn't matter. I used the volt meter to find the headlamp relay and the horn relay. It appears that two of the relays perform the headlight function - I made sure that it supplied power with either high or low beam selected.
I crimped a connector to the new power wire and attached it to pin 30 of the new motor-on relay. Pin 87 then got a short run of 12 gauge to the left side cowl where a ring connector was added and attached to the new aux fuse panel. The panel was attached to the back of the front console with hefty double-stick tape. If this fails to hold well, I'll drill a mounting hole and add a bolt and nut. Trying to not affect the asthetics at this point!
The new aux fuse panel mounted in the left cowl:
I used the Posi-Tap off the pin 87 wire from the headlight relay and used a crimp connector and some 18 gauge wire to route to pin 85 on the new motor-on relay. I like the Posi-Tap (first time to use them) and need to order an assortment (Napa just carries one type) from their online store.
Now there was a dilemma - where to pick up the ground? There were two shiny bolts on the square frame just below where I would mount the two new relays (not mounted yet) but they were just a bit too confined. So, off came the main front panel - 6 screws - four facing forward and two in the middle of each side pointing up - all 6 are easy to see. Once loose, I let the thing hang rather than disconnect 5-6 cables and risk missing one later.
I quickly rigged two 18 gauge black wires with ring connectors and a lug - one on each side. I also rigged a 14 gauge black wire with ring connector on the left (right side of scooter) to go to the horn.
You can see two shiny bolts here prior to attaching the ground wires. The panel is loose and hanging down a bit.
It is a good time to mount the two relays with the front panel loose - just a little more room. I used two tie-wraps for each relay, placing the just above the ground connections.
I plugged the ground wire on the right (left side of scooter) to pin 86 on the motor-on relay. Now was time for a power test - I connected the fused power wire to the battery and inserted a 30 amp fuse. I connected my volt meter to the lug on the aux fuse panel and to one of the unconnected ground wires.
key off - no voltage (good!)
key on - no voltage (still good!)
started motor - short delay - voltage (hooray!)
Shutting the scoot down, next task was the horn itself.
