Welcome! You'll love that thing. Go to a rally, these folks are really fun. Enjoy!
Answers:
1. YES preload your shocks. You are a big guy.
2. Perhaps on the idle adjustment. Also run premium gas and do not overfill.
3. (which you didn't ask) The manuals are here:
[topic630]
4. (which you didn't ask) The Yahoo! Vespa GT200 group is here:
http://autos.groups.yahoo.com/group/vespagt200
5. Here is a list of tips from that group....this will spark some discussion:
Use only mild soap and water on the wheels. Cleaners like Maguires or
even 409 can dull the coating. Powder coating to fix is an option.
2006 GT200's sometimes require the float in the carb to be reset.
Symptom is that it runs differently in different temperatures.
The Euro taillight does NOT use LEDs...just small bulbs.
The tan seat gets dirty easily. How to clean??? Personally, I have tan and I haven't found it getting dirty yet.
The fuel lines are prone to cracking. A replacement is available from ScooterWest.com for $15.
Do not overfill the tank with gas, ever. It floods the polution control equipment and can cause problems.
Remove the pet carrier when you fill up, that way, if you spill, it won't
make your raingear smell like the chevron.
Do not fill up at a station that has only one hose for three grades of fuel.
These tanks hold so little, the first gallon is just what was left in
the hose...and you'll be paying a premium for it.
If you are getting a windshield, get a full size one.
If you are changing the oil or draining the gear oil, use a front wheel
chock or have a friend hold the bike. The center stand is in the way
of both. I have been successful (twice now) at crafting aluminum funnels to avoid getting oil all over the stand.
Consider using a piece of aluminum foil to shape a "funnel" to drain
the fluids and keep them off the bike.
NEVER, EVER apply wax, shine, or armor all to your tires. When it rains,
this stuff becomes slick and will cause you to wipe out.
Don't install the rubber mat unless you are going to leave it on the
scoot forever, grit and debris collects under it and will scratch the
crap out of the paint under the mat.
If you scratch the paint, call aerocolours in your area. About $150 or
less to fix most anything.
http://www.aerocolours.com/
Learn how to do work yourself. Get a manual here: [topic630]
When the low fuel light comes on, you have 1/2 gallon of gas left.
Spark Plug Discussion:
Original = Champion RG 6 YC
NGK (Brandon) recommends base NGK plug stock #7411 CPR8E
10mm, 3/4" reach, 5/8" hex, gasket seat, resistor, projected center electrode
*OR*
New = NGK Iridium CR8EIX: Iridium IX plug, 10mm, 3/4" reach, 5/8" hex,
gasket seat, resistor, fine wire (0.8mm) platinum center electrode,
tapered cut ground electrode
NGK iridium plugs represent the ultimate evolution of spark plug technology and performance. The iridium center electrode is both stronger and harder than platinum. This allows NGK engineers to design an ultra-fine (0.6mm) center electrode reducing the voltage requirement for spark. This allows for a brighter, stronger spark from your existing ignition system. The ground electrode has a tapered cut at the firing end which reduces quenching for better flame core growth and increased ignitability.
The combination of fine wire center electrode and tapered cut ground
will increase performance, improve acceleration, and fuel efficiency.
From the manual: Recommended Lubricants...and then what is available in the US.
Rear hub: SAE 80W/90 oil, exceeding API GL3 specifications. TUTELA ZC 90.
I'm using Valvoline 75W90 full synthetic as it exceeds all specs and was
the closest weight available in my local market.
Air filter sponge: Mineral oil with specific additives to increase adhesion
ISO VG 150. SELENIA Air Filter Oil. I'm using the spray on oil from K&N.
Brake levers, throttle handgrip: Complex calcium soap grease NLGI 1-2. SYSTEM TW 249 AREXONS.
Engine oil: SAE 5W/40 synthetic oil, exceeding API SJ specifications. SELENIA HI Scooter 4 Tech.
First of all, API SM exceeds the old SJ standard. I put a pdf file
in the "files" section that explains this.
I cannot get the SELENIA oil locally. I searched, reviewed castrol,
AMSoil, and others.
I purchased a case of Valvoline fully synthetic SynPower SAE 5W40 from NAPA. I had to special order it.
Here's the poop: "Attributes : Motor Oil Style & Type : SynPower SAE 5W40.
Motor Oil Weight Rating : 5W40. Engine Fuel Type : Recommended for
Gasoline Powered Naturally Aspirated & Turbocharged Vehicles, Including
Luxury & High Performance Automobiles, Light Trucks & SUVs. Meet OE
Warranty Requirements : Yes. SAE 5w40: Provides the widest range of
protection available in the SynPower motor oil line. Delivers outstanding
cold temperature pumpability for rapid oil circulation at start-up.
Provides a thick oil film for ultimate wear protection. Exceeds all car
and light truck manufacturer's warranty requirements for the protection
of gasoline, diesel and turbocharged engines where an API SL, SM or CF oil
is recommended. Exceeds European ACEA A3/B3/B4/C3 and all preceeding
API Gasoline Engine Oils. Meets or exceeds the engine performance
requirements for BMW, Bentley, Corvette (GM4718M), Jaguar, Lexus,
Mercedes-Benz, Porsche, Rolls Royce, Volkswagen, Volvo and other
high performance vehicles."
Brake fluid: Synthetic fluid SAE J1703, NHTSA 116 DOT 4, ISO 4925. TUTELA TOP 4.
I found the Valvoline SynPower DOT 4 at Kragen. It's full synthetic.
Coolant: Monoethylene glycol-based anti-freezer, CUNA NC 956-16. PARAFLU 11 FE (Diluted)
Grease for driven pulley shaft compensating ring and moveable driven
pulley sliding seat: Molybdenum disulphide grease. MONTBLANC MOLYBDENUM GREASE (498345).
Grease for wheel bearings, pivot housings and swing arm: Lithium soap and zinc oxide grease NLG12 for the oscillating arm. TUTELA ZETA 2.
