Sun Jun 08, 2008 9:37 am
MP3 500
MP3 500
Sun Jun 08, 2008 9:37 am linkquote
I installed a throttle lock by ThrottleMeister (http://throttlemeister.com/tm.html).
I had these on my VTX and love their look and functionality. They are definitely expensive and you can find other throttlelock products for much cheaper. I love the factory look that these have when installed.
You will not find the MP3 listed on their application chart. Just order the model for the Triumph Rocket III. I got the heavy (14 oz per side) and the black fluted options.
Sun Jun 08, 2008 12:16 pm
MP3 500
MP3 500
Sun Jun 08, 2008 12:16 pm linkquote
So this is cruise control for bikes. How does it shut off? In, like, an emergency?
Sun Jun 08, 2008 12:34 pm
MV Saint
Haud yer wheesh't if ye cannae be nice
MV Saint
Sun Jun 08, 2008 12:34 pm linkquote
Just roll the throttle back. I have one on my motorbike and they are great for touring and playing scrabble
Sun Jun 08, 2008 1:39 pm
Gilera Fuoco 500ie
Gilera Fuoco 500ie
Sun Jun 08, 2008 1:39 pm linkquote
can you send me more photo and explain me better how it works?
Sun Jun 08, 2008 2:35 pm
MP3 500
MP3 500
Sun Jun 08, 2008 2:35 pm linkquote
ThrottleMeister for Fuoco
Luca,
This is from the throttlemeister site.
Once you've mounted the Throttlemeister bar ends to you bike, they work like this... All of the workings of the Throttlemeister are inside the bar end itself. Once mounted, you turn the whole bar end in the same direction as opening the throttle. A piston moves in and out of the Throttlemeister itself and puts friction against the throttle tube which in turn, counteracts the throttle return spring. When installed properly, the Throttlemeister will not completely lock the throttle, you can always override the Throttlemeister in any situation. If you need to stop quickly you can just grab the throttle and turn it off.
Sun Jun 08, 2008 3:13 pm
2016 MP3 500 Sport
2016 MP3 500 Sport
Sun Jun 08, 2008 3:13 pm linkquote
Throttlemeister
Ditto,
I've had them on 6 or 7 bikes and wouldn't be without them on the road. A little pricey but simple to install and aircraft grade quality.
Sun Jun 08, 2008 7:31 pm
mp3 250 & MP3 400
mp3 250 & MP3 400
Sun Jun 08, 2008 7:31 pm linkquote
8)
That's what I have on my 400. I had it on my 250 and moved it to the 400. Works great and I sometimes miss it on the 250.
R.B.
⬆️    About 3 months elapsed between posts    ⬇️
Sat Sep 20, 2008 11:23 pm
MP3 500 Demon Black
MP3 500 Demon Black
Sat Sep 20, 2008 11:23 pm linkquote
I just picked up a set for my MP3 500 from i-bike.com who sells them over the internet at a discount. Unfortunately they are in California, so I got stuck with sales tax.
Sat Sep 20, 2008 11:39 pm
Sat Sep 20, 2008 11:39 pm linkquote
if the throttle is set and you didnt turn it off and hit the brakes what happens?
Sun Sep 21, 2008 7:50 am
MP3 500
MP3 500
Sun Sep 21, 2008 7:50 am linkquote
I have got to get one...for the name alone. It's got to be good if it's the Meister!
Sun Sep 21, 2008 8:16 am
Sun Sep 21, 2008 8:16 am linkquote
Exactly what I was wondering.For example say a deer ran out in front of you, your first response would probably be to grab for the brakes.So would you also have to fiddle with the ThrottleMeister too?
Tim
Sun Sep 21, 2008 3:04 pm
2009 MP3 400
2009 MP3 400
Sun Sep 21, 2008 3:04 pm linkquote
Since we can't assume the throttle return will work when needed most, the first response should be to decisively roll the throttle off before squeezing the brakes. If the drag mechanism is correctly set, you'll overcome the friction easily. I'd worry more about a rider either cranking it too tight, or just forgetting it's on, and causing a problem.
Thu Oct 02, 2008 10:27 am
Thu Oct 02, 2008 10:27 am linkquote
Just a question about the weight. When you buy a Vespa top case they give you larger bar end weights to install to counter the weight of the top case. When you buy a Givi top case you receive nothing, no counter weight.
If weight balance is a concern does the Throttlemeister's weight affect the front end response or handling?
⬆️    About 9 months elapsed between posts    ⬇️
Fri Jun 19, 2009 3:20 am
Sponsor
Sponsor
Fri Jun 19, 2009 3:20 am linkquote
Re: ThrottleMeister for Fuoco
Anyone ever tried these on a Vespa 300Super or know of a similar product?
  DoubleGood Vespa Design
[ Time: 0.0395s ][ Queries: 8 (0.0155s) ][ Debug on ][ 209 ][ Thing One ]
