Sat, 21 Jun 2008 00:01:38 +0000
1966 Vespa 180 Super Sport
Sat, 21 Jun 2008 00:01:38 +0000 quote
I need to check the timing on a 1966 Vespa VSCIT. I have downloaded a deg. disc but not sure how to use it. The timing should be 26 deg. BTDC. Any help is appreciated.
Sat, 21 Jun 2008 00:10:59 +0000
0:7 And counting
0:7 And counting
Sat, 21 Jun 2008 00:10:59 +0000 quote
Moved to General Discussion.
Sat, 21 Jun 2008 09:55:37 +0000
Sat, 21 Jun 2008 09:55:37 +0000 quote
do you have a piston stop or is the head off so you can determine TDC?
best,
-greasy
Sat, 21 Jun 2008 17:36:36 +0000
Sat, 21 Jun 2008 17:36:36 +0000 quote
I don't have a piston stop and the head is still on but I have found a procedure on ignition timing under Team Vespa. I may use a screwdriver to determine TDC and an ohm meter to determine the current timing using the deg. wheel. Previously, I had removed the stator and had to rewire it due to the original insulation on the wiring had crumbled off. Before removing the stator, I marked its position but, must be off due to noticeable power loss going up hills and poor starting when engine is warm. All help is appreciated.
Sat, 21 Jun 2008 21:21:14 +0000
63' GS160, 06' GTS250
Sat, 21 Jun 2008 21:21:14 +0000 quote
This may help.
http://kavsud.com/vespa/maintenance/points_timing/pointsTiming.htm
Cheers.
-Kav.
⬆️    About 15y elapsed between posts    ⬇️
Mon, 18 Sep 2023 13:59:13 +0000
Motovespa 150s MK2 65
Mon, 18 Sep 2023 13:59:13 +0000 quote
Old topic but in case anyone comes across this here is a video about timing an older Vespa w points:
  DoubleGood Design
[ Time: 0.0326s ][ Queries: 4 (0.0095s) ][ Debug on ][ 286 ][ Thing Two ]
