vespa et4 125
vespa et4 125
hi there!i am new to this forum and if this is a new topic indeed...i have a vespa et4 and i am planing to make some changes on it.my priority is to change its colour!do you have any idea how can i re-paint my scooter as cheap and easy as possible(godamned money)????
1978 Vespa P200E
1978 Vespa P200E
Never tried it myself, but this dude painted a car for $50 and it looks amazing:
http://www.rickwrench.com/index79master.htm?http://www.rickwrench.com/50dollarpaint.html
@got_mine avatar
@got_mine avatar
Take a look at this member's scoot...
We all watched this from beginning to end...
+++++++CAN YOU SAY MATT?+++++NEW PICS ADDED!!
Great Rattle Can job
@tom_crusaders_sc avatar
'02 ET4, '66 Sears "bluebadge" '72Rally 200 '79 P-200 '57 Lambretta Ld
...the old fashion rattle can is the cheapest. try the "dupla-color" brand. you can find it at most any auto-parts joint. it's made to repair car paint.
...don't be afraid to remove parts from the scooter to paint. you'll probably still need to mask off lots of things so have some good masking tape and a razor blade for detailing... DONT RUSH IT!!! take your time and make sure the paint is dry before handling... most paint jobs get fucked up because people have no patience... several light coats is the key...
rustoleum and krylon are also excellent paint brands. pick a primer and clear coat that is the same brand of the paint... some formulas don't like each other... spend some time with your color choice...
proper prep work goes along way... i don't recommend 'sand blasting'. a good sander and steelwool should do it for most jobs... you don't need to take it down to the metal...
good luck and send pics of before and after, if you can
Brother Max's Et after paint. it was a stock silver.
[ Time: 0.0103s ][ Queries: 5 (0.0026s) ][ live ][ 339 ][ ThingOne ]
