Hi guys,
I purchased a restored '65 VBB. I am using a 2% oil/gas mix, with synthetic 2T oil. The exhaust seems very smokey at idle. What do you guys think?
Here is the video of the scooter in idle : http://www.domainoverdose.com/exhaust.avi
Thanks in advance.
@tom_crusaders_sc avatar
'02 ET4, '66 Sears "bluebadge" '72Rally 200 '79 P-200 '57 Lambretta Ld
...looks pretty typical. are you shutting off the gas? is your fuel tap not shutting off/leaking? sometimes a being a little flooded causes allot of smoke... but remember that you are burning oil/gas mix...
VBB 1965
VBB 1965
Thank you. The gas is shut off. Any other tips on how to minimize exhaust smoke? I'm worried the "green" movement here in san francisco will throw rocks at me while I'm driving.
@no_cattle avatar
2005 ET2 70cc, 14 mirrors, 2 headlights, lots of LEDs and a 2005 GT200 restored after a crash, 1978 SIL Lambretta GP200 and a 1983 Cushman Truckster
@no_cattle avatar
Invisible exhaust is often more harmful. And 2stroke engines are not "green" in any case. But your footprint is smaller, right down to using less steel in the last 30, 40yrs.
@bgk avatar
ET2
@bgk avatar
ET2
If a 2 stroke scooter doesn't smoke, something is wrong. But you can use some synthetics that are low smoke like Ipone. Even at 2% it's a lot less noticeable.
@rover_eric avatar
@rover_eric avatar
Yup. I thought the video looked pretty good, actually, in terms of smoke quantity.
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
when my px was smokey the clutch side oil seal had gone and was burning gear oil , check gearbox oil level and see if it smells of fuel ( gas )
did you measure the oil to fuel correctly 20ml oil to 1 litre fuel and no just a little bit more for luck Laughing emoticon
@killo avatar
I have a few scooters....
@killo avatar
You should see my SS180, if you think that's bad. Razz emoticon It runs 5% mix.
@tracysf avatar
74 Rally 200
@tracysf avatar
74 Rally 200
Just avoid starting your scooter in front of a bunch of tourists sitting at a sidewalk cafe in North Beach. For some reason, they always get annoyed when the 2 stroke smoke wafts over and interferes with their cigarette smoking.
I read somewhere on line that ipone is not full synthetic, that it is semi-synthetic.
While searching, I found a product they have called "Ipone Synthesis 2 Anti-Smoke": http://shop.motorcyclenews.com/ProductDetail.aspx?catID=(Lubricants)&prodID=make=Ipone%7Cmodel=Synthesis%202%20Anti-Smoke%20Pre%20Mix
I could not find any forum posts about this oil - only information on the strawberry shortcake version: http://www.scooterworks.com/2_Stroke_Oil-_Ipone_Scoot_City_P2432C214.cfm
Has anyone tried the "Ipone Synthesis 2 Anti-Smoke"?
@rover_eric avatar
@rover_eric avatar
How about the old LD's that run 6% ?
@bgk avatar
ET2
@bgk avatar
ET2
Try the strawberry version. It's not bad and doesn't really smell like strawberry. If you smelled regular ipone next to it you'd probably barely tell the difference. That anti smoke seems to be all pre mix so maybe it's the same stuff in a different targeted bottle (minus the strawberry scent).
[ Time: 0.0130s ][ Queries: 3 (0.0033s) ][ live ][ 339 ][ ThingOne ]
