Hello All,
I was wondering if someone could help direct me. I was riding my Vespa to work today (250 miles on odo) and the back end started to almost fishtail out...it took me just a bit to get it under control, but it almost felt as if I had a flat tire in the back. The pickup was relatively sluggish and I was getting the movement to left and right.
I checked the back tires and tire pressure is sound so that's not the issue. I need to check the underseat storage because I repositioned the security chains etc which may shift etc...when I turn adding more momentum weight.
I was wondering if anyone else had experienced the same problems.
Thanks,
