2006 Fly 150
2006 Fly 150
Is it possible to add a kick starter to a Fly 150? On a couple of occasions I have accidentally left the headlight on and awoken to a dead battery. As there is no kick starter and an automatic transmission plus the brake lever must be engaged to start the engine a push start is not possible.
TIA,
mdh
@louisiana_geezer avatar
Honda Shadow VLX (Fly 150 sold)
Don't think so, but you sound like the perfect candidate for the Battery Tender, Jr.
@fogie avatar
@fogie avatar
Re: Add kick starter to Fly 150?
How do you manage to leave the headlight on, without leaving the key turned on?
Since the Fly uses a LEADER 150 engine, you could presumably install the side case and kickstart lever from an LX 150; keep your eyes open for a wreck. But, from what I understand, the first time you use the kickstart, you're likely to crack the case; so, don't throw your old one away.
[ Time: 0.0085s ][ Queries: 3 (0.0015s) ][ live ][ 339 ][ ThingOne ]
