Salima Draghetta wrote:
I respectfully disagree with the other posters, but let me start by saying that I am just about the most technically dis-inclined person on the planet, so my opinion probably counts very little on this specific thread, and I can live with it. This said, if it were me, I would immediately siphon out the gas and put in the correct octane gas, the owner's manual is pretty clear on the kind of gas it takes, and for a loss of $ 7, I would never even want to come close to risking it.
Salima
I actually agree with you. If it was my ride, I would steal the turkey baster and the barf bucket (spaghetti pot) from the kitchen and suck it dry if it took an hour. Then I would pour in the required fuel. However, as obvious an answer as sucking it out is, the OP chose to ask alternatives. My suggestion of removing at least part of it (hopefully a big part) would result in an improved fuel supply that could be improved gradually.
Of course, I KNEW that there would be some who would come forth saying not to worry, no problem, you'll be fine, because they burn cat piss in their scooters to save a few dimes and they know more than Piaggio about the octane requirements of their engine.
As far as the ECU compensating, without a knock sensor, it CAN'T compensate because it has no way of knowing if there is detonation.
Let the flames begin.
