milobscootin wrote:
I felt I was "over" thinking the countersteering vs. just doing it (and again trying to overcome habits from my long distance cycling days).
That's the key. You know it's there, you know how to do it so just relax and ride and let your instincts take care of the rest. The same principles work on bicycles (You just do it far more often on powered cycles due to increased speed) so it's already ingrained into your sub-conscience.
The push is only out. If you put your scooter on the center stand and push down on the handlebars nothing will happen. If you push forward the handlebars will rotate. Rotation of the handlebars is what's needed to initiate counter steer. If you push down on the handle bars when the scooter is in motion you can initiate lean. Counter steering literally means to steer
counter to the direction of travel. If you want to turn left you steer your tire to the right and vice versa.
Here is a flat track racer in the classic exaggerated counter steering pose they take. This is exactly what you want to achieve in a very mild way.
This question makes me think you are a prime candidate for the MSF course.
Dave
