What can I use to make a glossy metaL surface (gold) matte? I want a silk matte, not a brushed look.
Any kind of sandpaper would be too abrasive, I guess.
Posts: 4332 Location: Utah Valley |
RIP
Any kind of sandpaper would be too abrasive, I guess. |
Festool makes a soft pad backed "buffing" sandpaper called "Platin" that leaves a not so glossy finish that is smooth as silk. They are in the 1000 to 2000 grit range. Use with water as a lube/coolant.
Their pads are hook and loop, so any brand of orbital will work. Sold in 5" and 6" sizes. Your local Festool dealer will have them in stock. They make a 3/4" foam spacer for use on curved work that would be highly recommended. Go to the Festool website to locate a dealer. |
Posts: 45634 Location: Pleasant Hill, CA |
Re: need abrasive agent
Moped wrote: What can I use to make a glossy metaL surface (gold) matte? I want a silk matte, not a brushed look. Any kind of sandpaper would be too abrasive, I guess. |
jimc wrote: Moped wrote: What can I use to make a glossy metaL surface (gold) matte? I want a silk matte, not a brushed look. Any kind of sandpaper would be too abrasive, I guess. |
Scotchbrite would be your best bet.
Try the different grades on another surface before hitting your part. I don't recall off the top of my head how many different grades there are & how they relate to sandpaper grits. (i.e. Scotchbrite "Fine" equals XXXX grit). http://www.industrial-supply-store.com/Abrasives+-+Accessories%7C%7CSCOTCH+BRITE+PADS%7C%7CkoNNbDu1z8hmU.php also you can get different grit polishing compounds or "rouge" to work in conjunction with it. http://www.swmetal.com/cart/search?category=Polishing%20Compounds The toothpaste idea works BTW....... |
RIP
toothpaste is excellent but my object has small indentations which would fill. The scotch Brit is a great idea, I will fry that next.
Toothpaste can be used both as a polishing agent (up to a point) and also as a very fine abrasive (which it is). Over here the proprietory brand "T-Cut" is very similar in effect. It appears to polish until you really look at the surface. It all depends on the observer's definition of 'polished' and 'matte' I guess.
Put it this way - I'd use toothpaste (or T-Cut) to clean up cellulose painted surfaces - I'd never use it on a plastic windscreen! |
Media blasting (aka sandblasting). I've put a satin finish on a number of things in my shop with our media blasting cabinet. Works well on aluminum and plastic, but would probably not result in a satin effect on steel, which is too hard.
If by "gold" you mean actual gold, I suspect media blasting would do the trick, gold being fairly soft. |
How about polishing compound. It's more abrasive than toothpaste, but not so much as to gouge.
Honda Fireblade - Suzuki DRZ-SM - Ducati 900S
Posts: 558 Location: Kitchener. |
Sandpaper comes in many grits; start out coarse and work your way up - it's how many people "polish" aluminium. The final polish would be with a polishing compound (duh).
Alright, this is my area of expertise! There are several different kinds of matte finish, and how coarse you want it will determine your grit. The cheapest and easiest way to apply a matte finish is with sandpaper. You will want 400 grit or finer. When applying with sandpaper, you want to make sure that you move in one direction as smoothly as possible for a professional look. If you have access to a dremel tool, you can purchase unitized fiber wheels for a smoother satin finish. They are specifically designed for this. I also find that I like the radial bristle brushes made by 3M, depending on how coarse a finish I want.
Sandblasting is another great option if you are looking for an overall matte finish with no directional grain (i.e. not brushed). There are many types of grits, but in general this is not the path for a satin (very fine matte, like silk) finish. If you do not have easy access to a sandblaster, however, I would not recommend it. The cost of renting or having a shop do it would not be worth it. If you are looking for the brushed stainless look, I would go with a 600 grit sandpaper, which you can tape onto a paint stirrer. Place the sandpaper grit side down and score it along the edges of paint stirring stick so that it folds smoothly around it on all sides. Then carefully use the stick in one direction (no waviness!) to get the effect you want. |
RIP
Thom wrote: Scotchbrite would be your best bet... I only had one variety at home and just used that, pushing hard to scrub the glossy surface over the scotchbrite pad, in an irregular pattern of circles, criss-cross action. It turned out just like I wanted it. Silky matte. Like a haze over the glossy surface, without any visible (to the naked eye) scratches or marks. Thank you Thom. I knew it would work, because the moment you mentioned it, I remembered messing up some new, shiny copper pots with the same pads, back in the day. |
Salima Draghetta wrote: Toothpaste ... mmmmmmmmm... now this makes me very curious, as to how/why according to you it works on gold to make it matte, but whenever I use it on silver it actually cleans silver to a sparkling beautiful shine with no damage whatsoever (zero abrasiveness) to the silver surface of the object. I have never used toothpaste on anything gold, so if you can explain the reasoning behind toothpaste's behavior on gold, I would be grateful. (I do not want to try this as an experiment on my own gold, in case it actually works, making the surface matte, which I do not want in my case -- I like my gold shiny, LOL). I polish all of my silverware and silver objects with toothpaste, it is the fluoride in toothpaste that cleans off the darkened oxydated (sp?) spots. I have done this for decades. All I do is rub the toothpaste on the silver object, gently, then put it under cold tap water to rinse, and the silver is as good as new, sparkling brilliant clean. Any toothpaste with fluoride will do the trick on silver. Regenerates it beautifully to a great shine. Can someone tell me why on gold fluoride toothpaste works differently than on silver, and it will make a matte surface on gold, but it super shines and cleans silver? Thank you, Salima Draghetta The first buffing compounds were made from very fine clay. The super fine particles produce a shiny finish. I hope that makes things clearer. |
mstevens wrote: When I saw the thread title, my first thought was "surely that would be Michael Ovitz?" Now there's an abrasive agent! ![]() Kevin |
Posts: 1946 Location: Oakland. 1000 posts, only 10 of any value |
Kevin wrote: mstevens wrote: When I saw the thread title, my first thought was "surely that would be Michael Ovitz?" Now there's an abrasive agent! ![]() Kevin
