@88andstillriding avatar
MP3 500
MP3 500
Has anyone removed/replaced their bar ends. Mine seem to be lock-tite solid and can't budge them without drilling.
Anyone else have this problem?
88
MP3 500
MP3 500
Barends
Mine came off quite easily using an allen to remove the bar end bolts. I had to do it to install the throttlemeister cruise lock.
@cheshiresoundlab avatar
MP3 500
MP3 500
Mine came off no problem. Actually I took delivery of the scoot and drove it for a few days before I realized that the one on the left side was missing. Laughing emoticon They had it at the shop so no biggie I stopped by and they threw it on for me.... Just got overlooked in "PDI..."
I've since replaced the stock grips with Kuryakyns (they are teh sweeeeet) so I have a pair of bar ends if you screw something up and need them... Hit me up if that becomes the case.
New gripsVV
@pieraldi avatar
MP3 500
@pieraldi avatar
MP3 500
Kuryakyns Grips link?
Can you send along a link for those - they look great.
@pieraldi avatar
MP3 500
@pieraldi avatar
MP3 500
throttlemeister cruise loc Detail?
Can you please send along detail for this as well...no fair to mention with no picts links or install input...
MP3 500
MP3 500
Re: Kuryakyns Grips link?
Lol! You might not appreciate the irony of that depending on how much combing through old topics and posts you've done here but I'll happy to oblige. Laughing emoticon
Damn! Right in the middle of your own thread here too, 88.... Sorry dude.
BAM!- http://scootertrap.com/
Laughing emoticon
MP3 500
MP3 500
Re: throttlemeister cruise loc Detail?
They're Kuryakyn Iso grips. The little doohickey on the throttle side is called a Throttle Boss (also by Kuryakyn but sold separately. Not Throttlemeister- I think that's a cruise control type of thing- different animal) and is positioned so that when I'm at my most common speed (classified) my palm just holds down the tab and my wrist isn't all twisted. They are pretty but I liked them more because I thought that the stock grips were a bit small for me and they felt kind of cheap to the touch so since that's the main human/machine interface (not counting your butt)...
They come w/instructions but I would suggest that you throw away the glue that they come with (or put it in your glue supply for some other use... It's basically superglue) and dry-mount them. You'll cut a shallow slit along the length of your rubber grips, peel 'em off and throw 'em away. Clean your bare bars, then the left side takes a little "building up" w/electrical tape to get a good fit. The throttle side holds pretty snugly as-is. Windex was suggested as a little lubricant to get things on and positioned. Then a cyclist I work with also suggested using hairspray as it dries tacky. That would prolly work- this guy puts a couple hundred miles on his bicycle every weekend so he should know a thing or 5 about handlebars. Me- I left 'em like so (since he suggested this after I was done) and the left side will twist but only if you try to twist it. The throttle side has held firm for almost 1K miles.
Cheers!
@ironhorse avatar
Gilera Fuoco 500
@ironhorse avatar
Gilera Fuoco 500
No Problem
My RHS came off no problem to fit a Vistacruise. Didn't try the LHS
MP3 500
MP3 500
Hey Pieraldi,
I have already done a post on the throttlemeister product on this forum.
?https://modernvespa.com/forum/topic27072
MP3 500
MP3 500
Throttlemeister
ThrottleMeister for Fuoco
88 when I removed mine I thought I was going to break the allen wrench but they eventully broke loose, then I installed jettin's that are color matched.
"Surprise" them with a hammer on the allen key.
do you have to sneak up on them and be very very quiet, like huntin rabbits
@dlg_az avatar
Piaggio MP3 250
@dlg_az avatar
Piaggio MP3 250
If I ever do decide to swap mine out, these are bar ends I wouldn't mind having. Adds some LED light for turn signaling a bit higher up.
http://www.aerostich.com/catalog/US/Two-Way-Bar-End-Indicators-p-18923.html
@johnwwwatson avatar
That One!
That One!
The 2 Cent Capitol of the World
I really like those, but at 360 viewing, so they are seen in front, back, and my side.
@dlg_az avatar
Piaggio MP3 250
@dlg_az avatar
Piaggio MP3 250
Re: The 2 Cent Capitol of the World
It's hard to tell from the picture, but the description states "let others know your intentions more clearly, whether you're coming or going". I found another article on them with some "show and tell" pictures.
http://tinyurl.com/2racq9
That One!
That One!
I think I like them!
Even if they cannot be seen in front, as far as I can tell, anything that increases our odds of telling folks behind us
that we are turning, is a good thing. A phone call before I ordered them, would be my first step.
@dlg_az avatar
Piaggio MP3 250
@dlg_az avatar
Piaggio MP3 250
I agree on confirming with a phone call, but the pix show they are visible from both sides. They sure are nifty.
Here's the specs:
Brand NEW bi-directional LED handle bar mounted motorcycle indicators from Oberon Performance CAD/CAM designed to increase safety and to alleviate most of the current LED aftermarket indicators issues.
Benefits:
* Improved motorcycle safety
* Highly visible mounted on end of handlebars
* Extra wide angle viewing pattern
* Visible from both front and back
* Instant illumination of indicator
* Small current draw
* Billet Aluminium
* High power amber indicator LED
* Elegant design
* Stainless steel fasteners
* Collets to suit 14mm to 22mm ID of Handlebar
By using 8 high power wide angle LED on each side of the circuit board the indicator is visible from both the front and back at the same time with equal luminosity. This has a substantial improvement on the visibity of the indicators which adds highly to the safety of the motorcycle and rider. Mounting on the end of the handle bar provides the greatest opportunity to be seen. LED's offer a much longer life than ordinary filament indicator bulbs.
Often LED's last longer than the motorcycle in which they are fitted. With the small current draw of LED's battery life is improved. LED's do not have a time delay on operation so they are instantly on at full power.
One of the commonest complaints of aftermarket motorcycle indicators is the quality of the lenses. Our unique lens envelopes the LED circuit board completely by 360 degrees providing a melt proof, shake proof and loss proof cover.
These indicators are CNC machined from billet aluminium and are available in black or silver anodised. Complete with stainless steel fasteners, sleeved cable and a brass collet to allow fitting to hollow handlebars for most motorcycle. 14mm to 22mm Indicator body size: 50mm long x 35mm dia
[ Time: 0.0171s ][ Queries: 3 (0.0092s) ][ live ][ 313 ][ ThingOne ]
