Re: MILEAGE UPDATE
michaelsvespa wrote: TODAYS MILEAGE 34007[ MILES] AND 82.94 MPG ZOOM ZOOM |
His - 2009 Kawasaki Vulcan 900 Classic LT, Hers - 2008 MP3 250
Posts: 541 Location: Modesto, CA |
2007 GTS, 2006 Kymco 150, '53 Blue Sparkle Gretsch, '66 Rogers Red/Black Onyx
Posts: 492 Location: Ciudad de la Reina de los Angeles |
Congrats on your passing 34,000 miles. Also, on your gas mileage. You must avoid jack rabbit starts and are able to cruise long distances without traffic signals at medium speeds.
I am a little skeptical of everyone's mileage claims as I find it hard to accurately determine. In California, the gas vapor sleeve on gas pumps makes it difficult to fill the tank without spilling gas as I generally have to lift the sleeve back just to get gas to flow. Unless you are filling the tank to exact same level each fill up, it is hard to accurately determine gas mileage. I suppose you could fill it to a visible level at the top of the tank, however this frequently leads to gas spills. |
Posts: 23105 Location: Harriman, Tennessee, Tn |
coprock wrote: Congrats on your passing 34,000 miles. Also, on your gas mileage. You must avoid jack rabbit starts and are able to cruise long distances without traffic signals at medium speeds. I am a little skeptical of everyone's mileage claims as I find it hard to accurately determine. In California, the gas vapor sleeve on gas pumps makes it difficult to fill the tank without spilling gas as I generally have to lift the sleeve back just to get gas to flow. Unless you are filling the tank to exact same level each fill up, it is hard to accurately determine gas mileage. I suppose you could fill it to a visible level at the top of the tank, however this frequently leads to gas spills. |
GT-200L & 1991 p200e
Posts: 505 Location: Northern Cal, bay area |
coprock,
It doesn't matter how you fill your vehicle. You simply divide the TOTAL miles by the TOTAL gallons. If you fill to the same point every time, then you can calculate your MPG from one tank if you confirm it with the TOTAL MPG. Since 84+ MPG defies the laws of thermodynamics, I suspect poster is saying he once got that mileage. I don't know how he did that even downhill with a tail wind. Downhill only gets you about 30% improvement on your MPG. Counting a down hill glide with the engine off isn't calculating MPG if you don't calculate the gas used for the uphill part. |
pointpergame wrote: coprock, It doesn't matter how you fill your vehicle. You simply divide the TOTAL miles by the TOTAL gallons. If you fill to the same point every time, then you can calculate your MPG from one tank if you confirm it with the TOTAL MPG. Since 84+ MPG defies the laws of thermodynamics, I suspect poster is saying he once got that mileage. I don't know how he did that even downhill with a tail wind. Downhill only gets you about 30% improvement on your MPG. Counting a down hill glide with the engine off isn't calculating MPG if you don't calculate the gas used for the uphill part. Congratulations on both your milage and fuel consumption. I'm impressed! |
michaelsvespa wrote: DEALER DOES IT ALL, I WRITE THE CHECK Over 34k that's amazing. I'm not far behind. How about a picture of a GTS with over 34,000 miles on it? |
09 GTS (sold) 2014 NC700XD
Posts: 5016 Location: Charlotte, NC |
Wow
Congratulations on the great numbers!
I can't wait to get past the 1000 mile mark, but I guess that won't take too long anymore. I still remember when I passed my 10000km mark in my first car... at a old rundown bus stop somewhere in northern France. Some things you never forget! But then again a car and scoot don't really compare that well... *offindreamland* |
i would love to post a picture, need to know how...... also need to find the camera...it still looks brand new.
Modern Vespa should have a place below you avatar where you can post you mileage. It'd be neat to see that stat along with your location, posts #, and what you ride.
Currently at 3500...not quite 35000! congrats! |
