@rinshu avatar
'73 Primavera 125 / '05 Stella/ '63 150GL/ '80 PX150E
@rinshu avatar
So I noticed a crack on the top left side of my headset on my GTS, starting at the opening under the mirrors, mysteriously appeared. To my knowledge there has been zero impact to that area but somehow the crack appeared anyway. So do dealers sell pre-painted headsets and if so how much are they? I guess I need to put something on the to stop the crack from growing in the meantime, what would be a good idea?
@ro22 avatar
2007 vespa gts 250ie, 2005 BMW R1200GS
@ro22 avatar
Get some JB weld at NAPA once its dry you can sand and touch up paint and be almost good as new
@icaro avatar
@icaro avatar
I've replaced one on an LX and it was more than $100, ouch.
If you want a cheap solution, try this:
http://www.scooterwest.com/item_detail/Chrome-Head-Set-Cover-GTS/873/
if you don't mind the shiny!
@windbreaker avatar
@windbreaker avatar
if you can get UHU allplast glue, that will reliably "weld" the ABS plastic
By i
⚠️ Last edited by windbreaker on UTC; edited 1 time
@benito avatar
@benito avatar
To answer your question yes the dealers can get prepainted replacement headsets for you.
@alfamoi avatar
White Gts 300
@alfamoi avatar
White Gts 300
I've read that the brake fluid can crack the plastic. Don't you have a leak (or your mechanics change the fluid? )
To fix your problem, you can dismount the cap, and weld the slit by dissolving the plastic along this one with a soldering iron.
[ Time: 0.0083s ][ Queries: 3 (0.0015s) ][ live ][ 339 ][ ThingOne ]
