I checked many bar end posts, but no one seemed to have this problem. I installed the top case for for GTS, and then it called for the heavier ends to replace the stock ones.
The bolt does follow the righty tighty, lefty loosey convention right?
The bolt doesn't want to budge. I fear too much torque will strip the hex slot; the only movement I sensed was that. I was using the little "L" shaped wrenches (broke both). Should I look for something more substantial? I believe the size is #4 (from another post). Is there a recommended oil/loosener that may help. The scoot is brand new, so age and rust should not be an issue.
Side note on top case install. I forget the particulars, but earlier today I read some posts about bouncy top cases. The instructions failed to mention that the backrack has plastic chrome caps in the holes for the two rear-most bolts. These caps fit into recsesses on the case and can easily appear integral to the rack, and some may skip the bolt step. I used a sharp blade and was able to find a crack to begin to pry the caps out. I wonder, is everyone with a bouncy case being held down by 4 bolts, two forward, and two to the rear? Mine is quite rigid.
Any tips will be much appreciated. By the way, my accessories are almost all here, and I will soon post a more official introduction and show off the new scoot. Thanks!
