does a roll back go all the way to ground level? Does the scooter have to be winched up a ramp of some kind, reason I'm asking is if tow straps have to attached where to you put them
pomansvespa wrote: does a roll back go all the way to ground level? Does the scooter have to be winched up a ramp of some kind, reason I'm asking is if tow straps have to attached where to you put them If not running it would need to be pushed or winched up on to the bed. It would think putting it on backwards and pulling it up by the lower shock mounts would work. your best best is to look for a service that speciallized in motorcycles. There are a few around here. Wayne B |
I had that experience just last Friday with a roll-back. Granted, my MP3 was running but had electrical issues ... like no lights, turn signals, console lights, kept blowing fuses ... now way I was going to ride it in traffic to the shop.
At any rate, it WAS a motorcycle-specific tow truck HOWEVER none in the area are equipped for the unique front end of the MP3. The guy couldn't use the standard hauling gear that's used for a motorcycle. It had to be driven up and he wouldn't do that, nor would I let him. I looked at the bed - it was a smooth steel surface, no sides; I did a visual sweep for oil/grease spots, then conjured up my game plan. Once the bed was rolled back to the ground, I took my MP3 out on the street behind it, gauged what I considered a good "running start" distance, gave it lots of throttle and zoomed up to the top of the bed sitting highest in the air, and grabbed the brakes and held on for dear life while it was tied down. That was the hardest part for me as I have rheumatoid arthritis in my hands. I kinda felt like Evil Knieval prepping for a jump. I got a kick out of it. And I'm sure the bed wasn't as high in the air as it looked, but it sure felt like it. Now, if it had NOT been running, I have no idea how it could have been put on that bed. When its totally rolled back, as long as that bed is, the front of the bed was pretty high in the air and the bike needs to be up there. Pushing it would be a real task. I think Wayne's idea of using the back shocks is about the only way I can see that it would make it up there in one piece. If you're that concerned about the towing, and if you can afford it, buy a cheap trailer from Home Depot, trick it out with a wood bottom and a couple Pingel wheel chocks, and tow it yourself. You can get a 4x6 trailer for about $500 from Home Depot or Lowers. And then you also have a trailer to tow it anywhere on trips or outings. That's what I intend on doing myself in a couple months. I seem to recall that "emptynest" has that type trailer and posted pictures here in the forum. Search on his user name and you'll find it. |
Posts: 45626 Location: Pleasant Hill, CA |
Here there are motorcycle 'SOS' vans that lower the whole floor of the van flat to the ground. Push on, tie down, raise and drive away. Brilliant.
jimc wrote: Here there are motorcycle 'SOS' vans that lower the whole floor of the van flat to the ground. Push on, tie down, raise and drive away. Brilliant. |
jimc wrote: http://www.sos-motorcycle-recovery.co.uk/index.htm ![]() And most of their drivers are bikers. It helps. |
jimc wrote: Here there are motorcycle 'SOS' vans that lower the whole floor of the van flat to the ground. Push on, tie down, raise and drive away. Brilliant. Googling to see what comes up for motorcycle towing equipment. Wayne B |
Wayne B wrote: ... at this point there aren't enough motorcycles on the road in the US for someone to spend that kind of money. The companies I know of in the Washington DC Metro area just use trailers. Nice and low to the ground. Wayne B But on the flip side, MC's and scooters are becoming the transportation of choice around here and one of those trucks would nicely pad my wallet, especially here in AZ. Those type trucks in the UK could also be used for ATVs, snowmobiles, golf carts, etc. There's a niche market for that SOS truck and if I had one, I'd surely find it ... starting with the Americade, the Sturgis rally, AmeriVespa, and so forth. |
MP3 500, Ducati ST4s, Honda Silver Wing
Posts: 2651 Location: Roseburg, OR |
The trailer you mentioned which you can get at Home Depot or Lowes, will do the trick (Best Way to Hook Up (6/11) an MP3) but that won't do you much good if you are a considerable distance from home. What I did the last time I got stuck with a flat, was park the bike in a somewhat secure area, called a friend to pick us up and drive us home, then come back with the trailer and pick up the bike. This was only possible with the availablity of a nearby friend, otherwise, all bets are off.
With roadside, a good point is made with our MP3's. With all its assets in having two front wheels, that same feature can hamper a tow situation since the company you call, being it AMA or AAA, will have a visual on a two wheel motorcycle, not three. When the tow arrives, no doubt he will scratch his head since MP3's aren't a common sight. What happens next will determine if your scooter will have future problems or be permanently damaged. JimC's SOS solution would be the ideal choice if it were available here in the U.S. |
It would be possible to put an MP3 on a 2-wheel tow lift, you would just have one wheel hinging off in the air.
Posts: 6256 Location: South Cumberland Plateau in Tennessee |
Don't makle it too complicated. When I had my blowout, I called a friend in the area. He came in a pickup with another fellow. Two of us picked up the front wheels and put them on the tailgate. Then we picked up the back end with the passenger handles and rear wheel being careful not to touch the hot exhaust, and rollled the bike into the pickup bed. We reversed the process to take it out. Backing up against a ditch or embankment reduces the lift required.
I called them as soon as I had the flat and before they got there 15 minutes later, 3 other pickups stopped and offered assistance. This was about every 5th vehicle on a lithtly traveled road. There are advantages to being in the southern U.S and away from freeways and big cities. Southern hospitality is a reality. I have lived in 10 states south of the Mason Dixie line and Georgia is not unique this way. I also spent a few years in Alberta, Canada and found similar attitudes. It probably is more the rural issue than reqion for people being willing to help a stranger. The number of pickups on the road helps too. You might be a redneck if you stop in your pickup to help someone broken down on the side of the road. |
dlg_az wrote: Those type trucks in the UK could also be used for ATVs, snowmobiles, golf carts, etc. There's a niche market for that SOS truck and if I had one, I'd surely find it ... starting with the Americade, the Sturgis rally, AmeriVespa, and so forth. |
MP3 hauler
Here is the link to the MP3 hauler described above.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=250268722617 I can not say how good this is, but it's an option. |
Interesting concept. I wonder how much pressure that puts on the suspension system of the automobile vs. a trailer type of hauler on wheels? I can see this type of arrangement for a scooter that handicapped people use to go to the mall, but for the beast? Wow!
Thanks for your link and photos! |
Serindipity0 wrote: Interesting concept. I wonder how much pressure that puts on the suspension system of the automobile vs. a trailer type of hauler on wheels? I can see this type of arrangement for a scooter that handicapped people use to go to the mall, but for the beast? |
Amen!
CheshireSoundLab wrote: Serindipity0 wrote: Interesting concept. I wonder how much pressure that puts on the suspension system of the automobile vs. a trailer type of hauler on wheels? I can see this type of arrangement for a scooter that handicapped people use to go to the mall, but for the beast? Jon |
Me either. Although their position would be defensible in a court of law, advertising a weight rating of 700 Lbs. is asking for trouble. That may be the rating of the rack itself, but in order to get a hitch/tongue weight rating that high you're out of any SUV that I'm aware of and into a fairly large pickup truck- probably at least a 250 series Ford or 2500 series Chevy/Dodge. I know my old 1500 Silverado had a tongue weight of 600 Lbs. and that was a 1999 Z71 with their "beefy" towing package. Again w/the weight of an MP3 400 or 500 that's pushing it a bit close for my comfort. Of course in that case... I'd just put the damn thing in the bed of the truck.
MP3 250
Posts: 148 Location: Alexandria, VA - woof! Just across the river from DC |
towing
Any recommendations for trailer to tow MP3 500... and no way would I try the ebay carrier shown in this thread! scary! I have a Toyota tacoma double cab and would like to tow my MP3 but really not sure what type of trailer to use ....
Posts: 23105 Location: Harriman, Tennessee, Tn |
Re: towing
wanderlust wrote: Any recommendations for trailer to tow MP3 500... and no way would I try the ebay carrier shown in this thread! scary! I have a Toyota tacoma double cab and would like to tow my MP3 but really not sure what type of trailer to use .... |
Re: towing
wanderlust wrote: Any recommendations for trailer to tow MP3 500... and no way would I try the ebay carrier shown in this thread! scary! I have a Toyota tacoma double cab and would like to tow my MP3 but really not sure what type of trailer to use .... BEST WAY TO TIE DOWN AN MP3 re: MP3 trailer |
You are very welcome.
If you do go the route of buying your own to modify like "emptynest," I'd suggest spending some money on a couple Pingel wheel chocks for the front. They are the only ones I've seen (so far) that have no extraneous parts like bolt brackets that stick out of the sides, so they can easily be mounted the proper distance to use with the two front wheels. |
MP3 Towing And African Queen, The Sequel.
dlg_az wrote: I had that experience just last Friday with a roll-back. Granted, my MP3 was running but had electrical issues ... like no lights, turn signals, console lights, kept blowing fuses ... now way I was going to ride it in traffic to the shop. At any rate, it WAS a motorcycle-specific tow truck HOWEVER none in the area are equipped for the unique front end of the MP3. The guy couldn't use the standard hauling gear that's used for a motorcycle. It had to be driven up and he wouldn't do that, nor would I let him. I looked at the bed - it was a smooth steel surface, no sides; I did a visual sweep for oil/grease spots, then conjured up my game plan. Once the bed was rolled back to the ground, I took my MP3 out on the street behind it, gauged what I considered a good "running start" distance, gave it lots of throttle and zoomed up to the top of the bed sitting highest in the air, and grabbed the brakes and held on for dear life while it was tied down. That was the hardest part for me as I have rheumatoid arthritis in my hands. I kinda felt like Evil Knieval prepping for a jump. I got a kick out of it. And I'm sure the bed wasn't as high in the air as it looked, but it sure felt like it. Now, if it had NOT been running, I have no idea how it could have been put on that bed. When its totally rolled back, as long as that bed is, the front of the bed was pretty high in the air and the bike needs to be up there. Pushing it would be a real task. I think Wayne's idea of using the back shocks is about the only way I can see that it would make it up there in one piece. .... Who are you? Not an ordinary woman by any means Not only doing it but standing up to Tow-Joe. Reading your Knievel Jump reminded me of Hepburn & Bogie in African Queen, you go Rosie Girl!!! Charlie: I don't blame you for being scared - not one bit. Nobody with good sense ain't scared of white water... Rose: I never dreamed that any mere physical experience could be so stimulating! Trailer: We seem to all be coming up with ideas. I found a 4x6 old MotoX trailer made from skill & desire. (looks like a VW cut in half, both ways, not kidding) it held 2 dirt bikes years ago and has tire grooves up front where 2 were, now my 1 MP3 will go! Hopefully, it will be emptynest worthy, but I doubt it Rosie , What turned out to be the solution to your MP3 trouble in the first place? |
Re: Amen!
BubbaJon wrote: My Gosh! I can't even imagine the 500+ lbs of my 400 all concentrated on a single pivot point and what looks like about 1-2 foot "fulcrum". No even on a bet would I try that thing. Jon |
Oops
CheshireSoundLab wrote: Me either. jimc wrote: ITYM "Me neither"... Even that is clunky... At least I 90% proofread before slapping something up. |
Re: MP3 Towing And African Queen, The Sequel.
johnwwwatson wrote: Who are you? No one special. Not an ordinary woman by any means Not only doing it but standing up to Tow-Joe. Hmm, my son says something similar ... have you been talking to my son? Reading your Knievel Jump reminded me of Hepburn & Bogie in African Queen, you go Rosie Girl!!! Aw shucks, thanks Bogey Funny you should mention Hepburn ... she's my favorite [deceased] actress; I always admired her gumption and style. Rose: I never dreamed that any mere physical experience could be so stimulating! It did make me a bit nervous at first, but I thought hey I can do this, what's the worst that can happen. It's one of those self-challenge things, I guess. Was better than the alternative of letting Tow-Joe do it. Rosie , What turned out to be the solution to your MP3 trouble in the first place? A minor thing, thank goodness. The wires for the 12v plug were crimped - one of the crimps came loose and the wire was dangling. So they put two crimps on it. All is back to normal now. I'm not fond of crimps. I think there are better alternatives. EDIT: I meant to add that it now makes sense to me about how the fuse kept blowing. I would be either ca. 100 feet from my driveway (the first time) and ten minute into a ride the second time when I went over a shallow speed bump and the fuse blew again. The dangling wire must have swung and came into contact with something each time that then shorted out the system and blew the fuse. |
