@bv avatar
Piaggio BV500
@bv avatar
Piaggio BV500
I think my scooter idle is runing too low RPM. How and where to adjust idle on BV500. Thanks.
@pdxscoot avatar
BV500 - GTS250
@pdxscoot avatar
BV500 - GTS250
If the idle is low, please read my post in Technical Reports on how to fix the Hose Clamp problem in the BV500. You should also make sure the spark plug is gapped properly (.028 - .031").
The idle adjust is accessed inside the pet warmer (storage area under the seat). There is a cover near the front with one phillips screw. Remove the cover. Turn the throttle and observe what moves. You'll see the cable turning a device over to one side. Right next to it in a counterbore is a male Torx adjustment knob. The proper socket for it is an "E4". They are hard to find, and when I got one, I had to turn it down on a lathe to get it to fit in the counterbore.
Adjust it when fully warmed up to 1440RPM +/-50RPM
I'd really check the hose clamps and plug gap first though.
@benito avatar
@benito avatar
Moved to General Discussions.
@bv avatar
Piaggio BV500
@bv avatar
Piaggio BV500
Thanks pdxscoot. You gave us such a wonderful informations. I appreciate.
[ Time: 0.0089s ][ Queries: 3 (0.0018s) ][ live ][ 339 ][ ThingOne ]
