@himfilth avatar
2008 Blue GT200 (Cringer)
@himfilth avatar
Went to leave work last night & my scooter died on me. Got about 1 1/2miles from work & its lost power. Stopped on the side of the road, let it set for a couple of minutes & just would'nt crank but it would turn over. I messed with it for about 30mins & no luck. Pushed it back to work & had someone to pick me up. Take it back to the dealer I guess.
@lomunchi avatar
2020 Honda NC750DCT
@lomunchi avatar
2020 Honda NC750DCT
By any chance had you just filled it up recently?
Our knee jerk response to GTs that loose power and won't restart is to disconnect the evap hose. If you haven't done it yet, do it, it's free.
@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
Re: Broke down again
"Crank" and "Turn over" mean the same thing. I believe you mean that the engine would not fire even though the starter was turning or cranking it over.
@himfilth avatar
@himfilth avatar
Where is that hose located at & luckily its still under warrenty. I've only had for about 2mths now.
Nightwing, it will turn over but not fire, your right
@himfilth avatar
@himfilth avatar
I can't remember but, when you turn the key on to crank it. Does the oil light normally come on.
@nightwing avatar
Contributor
Contributor
@nightwing avatar
Yes. It should go out once the engine starts.
@himfilth avatar
@himfilth avatar
Ok, thanks. I could'nt remember. Got it loaded up to take it to the dealer tomorrow.
@salty_dodd avatar
(GT200L) ... no more scoot :o(
@salty_dodd avatar
Here are the EVAP instructions: ET/GT/LX: Hard Starting, Rough Idle, or Stalling
@messycoloring avatar
LX 150
LX 150
well before you do that take a look at this ET/GT/LX: Hard Starting, Rough Idle, or Stalling
also you said you were leaving work, any chance some one tip it over and then put it back up?
@himfilth avatar
@himfilth avatar
I guess someone tiping it over could have happened but I did check it over good once I pushed it back to work. I park it on pavement plus put a small pad under the kickstand so it want tip over cause of heat. But I did'nt see any signs of that.
@himfilth avatar
@himfilth avatar
Finally got it back today. The problem was that the fuel control valve had went bad. Once it went bad as I was riding, it did'nt send any fuel to the carborator, making it shut off. Well now I got it back & I'm happy.
@trojanscoot avatar
2008 vespa LX150, 1986 yamaha CA50
@trojanscoot avatar
thats good it got fixed... hope it was covered under warranty
-cheers
@himfilth avatar
@himfilth avatar
Yep, it was. Only had it for a couple of mths.
[ Time: 0.0160s ][ Queries: 6 (0.0036s) ][ live ][ 339 ][ ThingOne ]
