I tend to sit back on the pillion for comfort's sake and I would like some sort of a peg behind the passenger's pads for my feet. Anyone had any experience with that?
Anyone know of any aftermarket pegs solutions?
Anyone know of any aftermarket pegs solutions? |
Posts: 1496 Location: Crofton,MD |
I'm actually looking for something that would fit further back, roughly above the kickstarter.
If you had the rear crash guards couldn't you put a peg on that? Motorcycle catalogs have tons of pegs that clamp onto various size engine guards that I bet would fit.
I saw that post a couple of days ago..
He had crash bars on rear and BMX style footpegs clamped on for his son to ride on... Give me a second or two....... Best Farkles You've Ever Seen? Half way down the page... Does this help? |
Man, I thought I was being clever! I was actually thinking more like cruiser motorcycle pegs. Kuryakyn is one of many manufacturers. They have dozens of styles and also make adapters to move them in any direction you might want.
Of course the BMX one posted kind of matches the grips better. ⚠️ Last edited by BoomieMCT on UTC; edited 1 time
Those are exactly what I'm looking for, just need to add the rear crash bars.
I knew you guys would have a solution! |
Is this a poll worthy question?
Who else thinks they spend way to much time here...?
Found that answer way to quickly... Now ask about oil and we will be talking for hours/days.... |
Oil the pegs, the hand grips and the seat...
Must keep everything pliable.... I would also rub oil into the rubber of the tires.. Helps to repel water... |
Also put oil in your gas to lubricate the engine. If it is good enough for 2 strokers it's good enough for us!
BoomieMCT wrote: Also put oil in your gas to lubricate the engine. If it is good enough for 2 strokers it's good enough for us! |
got mine wrote: Oil the pegs, the hand grips and the seat... Must keep everything pliable.... I would also rub oil into the rubber of the tires.. Helps to repel water... |
SkipJenkins wrote: got mine wrote: Oil the pegs, the hand grips and the seat... Must keep everything pliable.... I would also rub oil into the rubber of the tires.. Helps to repel water... My oil has no such warning. No sticker = it must be okay. |
SkipJenkins wrote: got mine wrote: Oil the pegs, the hand grips and the seat... Must keep everything pliable.... I would also rub oil into the rubber of the tires.. Helps to repel water... Funny now... repeat NOW..... not 20+ years ago... |
