Sat, 19 Nov 2005 23:17:48 +0000
Sat, 19 Nov 2005 23:17:48 +0000 quote
Thought I'd share with everyone a little "scare" I had today after I returned home from a nice ride. I rode about 50 miles in 7 degree Celsius weather through some beautiful amish country. When I got home I left the scoot in the drive and went in to watch Ohio State. I glance out the window and I see oil on the ground under the scoot. I went out to check and sure enough there is oil dripping under the scoot onto the drive. Upon further inspection I saw oil all over the inside of the front fender and rear fender. Hmmm. Motor's near the back. I check the oil - perfect, rearend, - perfect, coolant (just in case) - perfect. Then I remember seeing a big puddle of oil at this little place I stopped for coffee... I thought I missed riding through it but guess I didn't. Good thing I didn't go down after riding through that stuff. Sooo, if you ever see fluids dripping from your scooter it might not be coming from the scoot but from something your rode through.
⚠️ Last edited by BVBob on Sun, 20 Nov 2005 00:33:52 +0000; edited 1 time
Sat, 19 Nov 2005 23:55:13 +0000
None! I sold it :(
None! I sold it :(
Sat, 19 Nov 2005 23:55:13 +0000 quote
Oil drip?
I bet you were glad it was not yours. I found oil under my Gt this summer. Not much on the concrete, about a fist size stain. Checked the scoot, sure enough low on oil. After I topped off, phoned dealer and set up an appointment. They ended up replacing the rear housing gasket, "under warrantey".Glad that did not happen to you, Beale.
Sun, 20 Nov 2005 00:32:57 +0000
Sun, 20 Nov 2005 00:32:57 +0000 quote
I remember reading your post about when that happened or someone else's about oil under their scooter and that's one of the first things that came to mind. Since the oil was dripping off the front I felt a little better knowing the engine was more in the back. I checked the motor area for leaks right away.. Thank goodness. Cleaned everything up with some orange de-greaser and went in the house and had a few beers...
Sun, 20 Nov 2005 15:18:32 +0000
Vespa GT & Vespa LX
Vespa GT & Vespa LX
Sun, 20 Nov 2005 15:18:32 +0000 quote
We did exactly the same today... out onwet & oily roads.. pulled up & the wife jumped off the back "Your scooter's pissing out oil" she said..
Had a good look - looked too black (my oil is nice & clean ) - then saw it was dripping from the stand, rear mudguard & under the front.. was just the horrible winter road coating (thank goodness)..
Mon, 21 Nov 2005 18:06:34 +0000
Mon, 21 Nov 2005 18:06:34 +0000 quote
Thank goodness you didn't go down after going through oil.
Mon, 21 Nov 2005 22:47:45 +0000
Mon, 21 Nov 2005 22:47:45 +0000 quote
The scary thing in my situation is that when I left the parking lot where I think I rode through the oil, i was on a two lane divided highway with a 55 mph speed limit. Thank goodness is was a straight road for about 5 miles. I was paranoid yesterday on my "relaxing" ride through the park and stopped twice to check the tires for oil.
  DoubleGood Design
[ Time: 0.0275s ][ Queries: 3 (0.0051s) ][ Debug on ][ 299 ][ Thing Two ]
