What I liked about it is that you do not need to hard wire it in. The 22g wire can be inserted into the unit, and then removed when you no longer are using it. This was important, since I understood these hour/tach meters do not really stand up well inside the engine compartment. I've left the wire attached to the spark plug wire, and just tied it off to the side of the engine compartment for when I want to use the tach.
It is slow, and refreshes in 10 second increments. So you have to be patient when setting your idle.
