tired of those stock hard grips?
do you need more comfort?
REPLACE THOSE TIRED GRIPS
I replaced mine with a gel style sport bike grip.
#1 lay out your tools: grips, glue, razor-knife (thats all I used)
#2 remove bar-end weights
#3 carefully cut grips off the throttle side. Don't cut down real hard as you don't want to cut into the throttle plastic sleeve.
#4 clean handle bars with a clean rag (the old glue rubs right off)
#5 cut out ends of new grips (only if you have bar-end weights)
#6 sparingly glue handle bar area
#7 lightly lubricat the end of the grip prior to sliding on ( I used a little spit on my finger)
#8 when sliding on the trottle side twist on in a clockwise motion (towards the front of the bike) till grip completely is against the flared part of the throttle sleeve.
#9 adjust/align grip to your liking
#10 reinstall bar-ends weights
#11 let sit 8 hrs or overnite and your good to go
forgot to tell you how long this took 20 minutes and that included taking the pics
