@michael_h avatar
2006 LX150 "Amadora"
@michael_h avatar
Today I took my LX150 out for a country ride. Was managing well at 90-100 kph (around 55-60 mph) when I suddenly lost power. The scooter would run at 20-30 kph, and anything faster would cause the engine to first speed up, then sputter, and then the scooter would start to lurch - all while remaining at the 20-30 kph.
On the roadside, I was able to check some things. Plenty of gas, and from a reputable station. Starts up immediately, and revs while on the centre stand. No obvious dislodged hoses, and the carb did not smell of excess gas. From a dead stop, it would pull away and speed up to 20-30 kph easily. Adding more throttle made the engine sound like it was revving faster, and the sputtering and lurching would then begin. it seemed quite content to putt along at 20kph as long as I didn't add more throttle.
Fortunately, this all started as I was returning home, and I was only about 5 km from my house. I was able to cross the highway and slowly meander my way back home along quiet residential streets.
I'm thinking drive belt, but the mileage is rather low 8700 km. On the LX150, the belt doesn't have to be changed until 10,000 km.
I'm going to have to take it apart and check, but can't do that for a few days due to other time constraints. I just wanted some knowledgeable opinions on what likely is wrong.
Thanks.
⚠️ Last edited by michael_h on UTC; edited 1 time
@woodenhead avatar
GT60
@woodenhead avatar
GT60
Generically speaking , it sounds like a fuel filter or fuel line problem. Don't the lx's have a history of bad fuel lines ? Bad pick-up in the tank ? Does the lx even have a fuel filter ?
Edit : did a search and saw that it's the et4s that have the bad fuel lines, but also saw that you've been mucking about with yours recently. Check to see that your clamps are right/tight and that you haven't got a collapsed line or any kinks. Did you get the right size ? And fuel line ? It sounds starved for fuel.
good luck.
@michael_h avatar
@michael_h avatar
good luck.
Good idea. The LX doesn't have a fuel filter, but I have replacement line (which I hadn't yet put on). Does the fact that the scooter revs fine argue against a fuel line problem? I ask because I was thinking the problem was just when it was under load (me) as opposed to sitting on the centre stand.
But it is worth the look - and I really was supposed to have changed it at 6000 km. So, thanks for the reminder!
@woodenhead avatar
GT60
@woodenhead avatar
GT60
Another thing to consider - pop your stock sparkplug back in . Didn't you put in an iridium plug? Perhaps it's failing. My money's still on your fuel supply, though.
cheers
@michael_h avatar
@michael_h avatar
cheers
That's something I had not considered. Are the iridium plugs more prone to failure?
Also, I wanted to give you a big round of thanks! You've always been there to help with my scooter problems! Clap emoticon
@woodenhead avatar
GT60
@woodenhead avatar
GT60
Remember our discussion on whether to gap them or not ? It seemed that the reason to not set the gap was the fragility of the electrode. I've never used those plugs (they sound like a good idea), but it's always a good idea to check the obvious stuff first. Sometimes when a pug is failing or getting fouled they act up under stress. Not being familiar with them, it's just something I'd check.
Let's see if I'm right first ! I hope I'm not leading you down a blind alley.
It seems that belt or roller problems affect acceleration or top speed. Sputtering sounds like something else. But I could be wrong. I'm no greasy125. That guy knows scoots.
Hopefully your scoots problems are minor. Good luck.
@ianp avatar
Destroyer of Worlds
LML Star 125, Vespa GT200
Destroyer of Worlds
@ianp avatar
Check the plug first. Cap and wire next.
Then move on to fuel supply. Have you disconnected the Evap system? Do they even have one on Canadian bikes?
Then, check the CVT.
Beyond that, talk to greasy.
@ramrezz425 avatar
@ramrezz425 avatar
Check this...
Fuel tap vacuum hose may be kinked or cracked, Check for proper fuel tap operation., Main jet may have dirt as well, Depending on the milage I usually have to fix these issues most. dr
@woodenhead avatar
GT60
@woodenhead avatar
GT60
Re: Check this...
Welcome back!
Real estate not so great? Razz emoticon
@vincigpr avatar
Vespa 150s
@vincigpr avatar
Vespa 150s
You just changed the jet to the 38 right. Maybe check the snugness of the jet. If the plug is fouled let us know, I'll have to do some adjusting to my fuel mixture as well.
@michael_h avatar
@michael_h avatar
That sounds very reasonable, and the first thing that I'll do tomorrow (because it is easier for me than changing the fuel line). Also, I had rejetted the carb and that may have changed the fuel/air mixture, fouling the plug. I feel silly for not thinking of that myself.
@michael_h avatar
@michael_h avatar
Fuel supply is good, and gas is of good quality. Evap system has long been disconnected. Canadian bikes are the same as American ones - they just ride a little more to the left
@tnruss avatar
LX 150, GTS 300
@tnruss avatar
LX 150, GTS 300
Are you getting water in your tank due to the recent addition of ethanol in gasoline? Just had a discussion of this with our local shop owner, who is beginning to see this with bikes coming into his shop. Ethanol absorbs water. Water being heavier than gasoline sits at bottom of tank, ready to be swallowed up in big gulps by your engine. He recommends using Stabil to combat the problem.
@ramrezz425 avatar
@ramrezz425 avatar
Re: Check this...
woodenhead wrote:
Welcome back!
Read cfargos topic, "How has the economy affected you" I posted my story there. DR
@michael_h avatar
@michael_h avatar
That would explain the sputtering, but not why the engine revs increase but the speed remains the same. Still, we do have ethanol in our gas, and I have extra stabilizer, so worth the try.
Looks like I need to make a list of what to check first.
1. spark plug - because of the recent rejetting
2. carb main jet - could be clogged
3. change out the fuel line - because I am just plain lazy and should have already done it
4. add fuel stabilizer - easy enough to try
5. fuel tap - I'm not sure how to check this
6. belt - bugger!
I also wanted to thank everyone for their helpful advise and guidance!
@michael_h avatar
@michael_h avatar
update: no solution yet, but I appreciate the help
Two weeks and still no luck. What I have done:
-replaced the fuel line (which I was supposed to have done earlier),
-cleaned my air filter,
-pulled and replaced the plug (the original looked fine, but wanted to be sure),
-checked the wire and cap. They were fine, but I managed to yank off the cap while jacking up the body, so had to reattach it
- pulled off the transmission cover and checked the belt since it was on the table already - looks fine
Put it all back together, took it out last night and the exact same problem. Starts fine. Idles well. Revs nicely on the stand, to the point where it looked like it might jump off of the centre stand. I can ride it to about 10 kph, and any more causes the engine to sputter and die.
I'm going to do the last suggestion - putting Stabil in the tank - while I try to see if I have towing coverage on my CAA membership.
Any other suggestions I haven't tried? I'm starting to think that there is a problem with the carb.
@ianp avatar
Destroyer of Worlds
Destroyer of Worlds
@ianp avatar
Immobilizer?
@benito avatar
@benito avatar
Michael, I hope you have CAA Plus as that is the coverage you'll need to have a scooter/motorcycle towed.
@greasy125 avatar
@greasy125 avatar
Immobilizer?
probably not the immobilizer-- it revs out clean, so that would rule out any kind of keyed ignition problem.
best,
-greasy
@greasy125 avatar
@greasy125 avatar
i, too, am going with a fuel delivery issue.
well, at least initially.
but there's several variables...
personally, i'd start with draining the tank and going thru the carb.
then double checking the fuel/vaccum lines and tap...
best,
-greasy
2009 gtv250
2009 gtv250
SPUTTERING
how about bringing everything back to stock specs. plug, jetting, etc. sometines all factory settings and parts are the way to go. with those low miles, i would think it is something that was changed rather than something that just happened on its own. what was the last thing you changed or fixed on scoot before this problem Bring jetting and everything back to stock and i bet it will run perfect EDDY
⚠️ Last edited by eddy L on UTC; edited 2 times
@michael_h avatar
@michael_h avatar
I have CAA Plus so it should be alright.
@michael_h avatar
@michael_h avatar
best,
-greasy
The fuel system and carb is straying beyond my capabilities. Too much risk of really botching up the job if I don't know what I am doing. I am wondering how much of a coincidence it is that this began after I installed the 38 idle jet.
I appreciate the help. I'm going to make some calls today to see how quickly the shop can get on this (if they aren't too busy prepping the snow mobiles or doing end of season maintenance on the sport bikes)
@michael_h avatar
@michael_h avatar
Now it works!
Road a roller-coaster of emotion today. Frustration (that I had to have my scooter hauled to the shop today), astonishment (when it ran fine for the mechanic, but didn't for me just last night), embarrassment (that I had the damn thing hauled to the dealer, across town, for seemingly nothing), anger that I wasted two good weeks of riding and hours working on the scooter when I needn't do so), disbelief (when told that it was fine and that nothing needed to be done), relief (that costly repairs were not necessary), and finally, elation (when riding it back home}!
Turned out (we think) that some dirt must have got stuck in the carb main jet. A small clear hose, which attaches to the front left of the carb, was off and that may have let the dirt in. I don't recall taking it off, but it may have been pulled off when I was fiddling with the carb jet replacement.
Once he received it, the mechanic revved it quite a bit, and hard, and it seemed to work well. He took it for a ride and pronounced it OK! He figured that the speed at which it began to sputter and die was around the point when the main jet would be involved, and that it must have been plugged or something. Anyways, it is okay now.
The good out of this, is that I finally got to some of the routine maintenance I needed to do to the scooter, and I learned that the mechanic does some of this work on the side, so now I have someone local I can call for help!
Kevin - If you're reading this, thanks!
@benito avatar
@benito avatar
Well that is great news Michael, I'm really happy for you. You've learned so much about your scooter now after doing all of that work yourself. It is good to know that you have a good mechanic nearby for those hard to diagnose problems that you might have in the future.
2009 gtv250
2009 gtv250
sick scoot
im glad its over for you. no one likes down time, its a bummer . good luck EDDY
@woodenhead avatar
GT60
@woodenhead avatar
GT60
cheers
[ Time: 0.0309s ][ Queries: 3 (0.0240s) ][ live ][ 343 ][ ThingOne ]
