Notice
NOTICE!
Modern Vespa Private Message Changes
Changes to Modern Vespa's Private Message service are coming. Read about it here.
Mon Sep 22, 2008 7:07 pm
Willow Rouge: Excaliber Silver MP3 250 VIN 3288
Mon Sep 22, 2008 7:07 pm linkquote
I was feeling around the saddle latch lock and must have tripped something...Now, though the key works, it doesn't open the sadde seat compartment lock...When I press the key button, it makes the opening sound, but then makes another sound like it may be locking it again...
I was feeling for a manual release..Well, now I know there isn't one, but there is a little tab like thing, I felt, which I must have changed the dynamics of the locking gizmo....Well, now I've done it.
It won't budge. It locked shut.
What did I do? How can I fix it? I really hope you techno-wizards can help me out.
Thanks.....jacq
Mon Sep 22, 2008 7:11 pm
Mon Sep 22, 2008 7:11 pm linkquote
Hmmm...having trouble trying to depict what you're saying happened, but here are some tricks I've noticed with the seat lock.
1. Try pressing hard down on the back of the seat and then pressing the unlock button while doing this
2. Try pulling up on the back of the seat while pressing the unlock button
3. Turn the bike on, get on the seat, then get off and press unlock
4. Start up the bike and while its running, get off(with tilt on!) and press the unlock button while its in the ignition.
If none of these work, you most likely have to get the key reset(see manual and other posts on here about resetting the key)
Hope that helps. The seat I have noticed on the 250 and the 500 both have a sort of safety feature where sometimes the lock will make a double sound as you describe but the second one fails to unlock the seat. Most the times, applying pressure to the seat sensor and then releasing will 'reset' this feature. I have absolutely know idea why this happens or why this works, but it does.
Tue Sep 23, 2008 4:29 am
Tue Sep 23, 2008 4:29 am linkquote
Darn, none of that worked...Look at the pic.....Does any of that look normal...???? Rats...
I put a mirror and extra light down there and took a picture.
Maybe I changed the position of the RED tab thingy. It points at the medal post that's attached to the seat... I'm wondering if these 2 talk to one another and I interrupted their ability to communicate.....hmmm.
help.................Jacq
This is the mirror image of the locking area...
Tue Sep 23, 2008 5:59 am
Tue Sep 23, 2008 5:59 am linkquote
Fix Saddle/Seat Latch
Okay...I got it....Check out the picture...It looks like the RED thingy(designer talk and mechanic's nightmare) should be turned the other way, but, I couldn't get it to do that....Should I keep trying? It does work now....
I temporarily screwed up the opening mechanism by unlatching the medal wire that pulls the latch forward when the bottom is pushed. All of this you can't see unless you put a mirror and light to it.
The BONUS is...I unexpectedly discovered a way to get into the compartment and unlatch the saddle manually....Tough, but do-able.
Again, should I try to turn the RED thingy around or let well enough alone?
Geezz...jacq................cheers
Red Thingy on the wrong side....ie....Screwed
Tue Sep 23, 2008 6:00 am
Tue Sep 23, 2008 6:00 am linkquote
Red Thingy on the wrong side....ie....Messed Up
Red Thingy on the Right side...ie...Unmessed Up
Tue Sep 23, 2008 6:03 am
Moderatus Rana
MP3 250 (sold) MP3 500 (current)
Moderatus Rana
Tue Sep 23, 2008 6:03 am linkquote
Hi Jacq,
Looks like you pulled the red sleeve off of the silver peg next to it. Here is a picture of mine. Red sleeve over silver peg which I believe is slotted. Good luck!
Tue Sep 23, 2008 6:35 am
Tue Sep 23, 2008 6:35 am linkquote
Ahhh.....Right you are.....Silly little bugger....
Thanks so much for going to all that trouble in taking the pic...That really helped....
Wow...that just makes me appreciate how much trouble this stuff is for you guys with your bigger fingers dealing with those tiny mechanisms..geez...it's hard for me with my lady size 7s.....
Thanks Sticky and Luthor for coming to the rescue....
Really the Right Way....
Tue Sep 23, 2008 7:08 am
Moderatus Rana
Moderatus Rana
Tue Sep 23, 2008 7:08 am linkquote
It was no trouble at all Jacq. Just glad to be able to give back in this forum since I have learned so much here myself.
Tue Sep 23, 2008 7:49 am
Tue Sep 23, 2008 7:49 am linkquote
I'm just really impressed that you were able to take a pic with a mirror and an extra light . Glad you got it fixed.
Tue Sep 23, 2008 9:15 am
Tue Sep 23, 2008 9:15 am linkquote
do you know what caused this to happen the no pets sticker is backwards
glad to read about this thread and your outcome was successfull
Tue Sep 23, 2008 9:32 am
RIP: MP3 500 - Brutto Moto
Tue Sep 23, 2008 9:32 am linkquote
Mirrors do that....
Tue Sep 23, 2008 9:41 am
Tue Sep 23, 2008 9:41 am linkquote
I gues it should have stated this way bubba
you know what caused this to happen,
tada
Tue Sep 23, 2008 9:58 am
Tue Sep 23, 2008 9:58 am linkquote
Boogered It Up
Geez Whiz... Since I caused this problem with one little finger, what kind of horror would I creat with a paddle bit, drill and some electrical wires.....????
I'm thinking I should let Jimmy put in the accessory outlet....Pay the dude and be done with it.....
Thank God for you guys....
jacq....cheers
Tue Sep 23, 2008 10:05 am
Tue Sep 23, 2008 10:05 am linkquote
Re: Boogered It Up
jacq....cheers
but if you pay someone else what fun is in it for you
go for it
and take some pics and post for us
Tue Sep 23, 2008 10:48 am
Tue Sep 23, 2008 10:48 am linkquote
Hmm...I did find out what happened. I did find a way to get into the compartment without a key...I did find the manual latch and I did fix it...sort of ... with stickyfrog straighting me out...sooo...maybe you're right.... Had 1 negative and 4 positives, 5 positves if you count me swallowing my pride and asking for help after I accidently tripped the toggle.
I do like learning new things... Logically, it makes sense to keep trying...even if feels spooky..
Thanks....dirt....Okay...I'll go to the store and get the stuff...
Cheers....jacq
Tue Sep 23, 2008 12:34 pm
Tue Sep 23, 2008 12:34 pm linkquote
cool
can't wait to see the new stuff you are going to do.
Tue Sep 23, 2008 3:21 pm
Tue Sep 23, 2008 3:21 pm linkquote
Jacq, good for you girl.
Tue Sep 23, 2008 4:44 pm
Piaggio MP3/250
Piaggio MP3/250
Tue Sep 23, 2008 4:44 pm linkquote
My pull cable disconnected too. I think a Wally World bag snagged on it and pulled it off, but that is just a guess. I did remember a bag snagging just before I noticed it would not open anymore.
⬆️    About 13 years elapsed between posts    ⬇️
Fri Jun 25, 2021 6:49 am
Vespa ET2, MP3 250ie
Fri Jun 25, 2021 6:49 am linkquote
Reviving this old thread 10+ years later!
My 2008 MP3 250 seat opener was inoperable with the key when I bought it back in November 2020.
I could reach in through the trunk and unlatch it that way. Been doing this with no complaints! Using a cloned key from AF1 racing (no button) and leaving my original slave at home anyway since the seat opener doesn't work.
Recently something happened where the seat latch was in the locked position when I tried close the seat, so it wouldn't latch or lock! I pretty quickly figured out a way to unlock it manually by fiddling with the latch in through the trunk. Back to business as usual opening my seat manually.
Until last night! Seat lock is in the locked position again, while the seat is unlocked, and can't get it to open, can't figure out what I did before to open it to latch the seat closed.
Maybe it's time to fix it properly with the key switch and all. I do have a spare seat cable if need be- a mechanic at the shop I bought the MP3 at convinced me I may need a new cable to fix it and I ponied up $25 to AF1 racing for it, but never brought it back to the shop because opening the seat manually never bothered me.
The pictures in this thread will likely help! Just posting to let everyone know how useful a resource this place still is!
Also if anyone does want to PM me tips incase I lock myself out that would be much appreciated! I realize I've kinda lucked out having the lock stuck when the seat is opened and not closed! I do worry a little bit riding the bike putting weight on the closed latch of the lock, maybe I've made it worse and don't know yet... anyway thanks for reading this far
  DoubleGood Vespa T-Shirts
[ Time: 0.0689s ][ Queries: 28 (0.0455s) ][ Debug on ][ 189 ][ Thing Two ]
