Just bought a second hand 125 vespa et4 and the oil warning light comes on and stays on when the engine starts
Checked last owner service book and it has been highlighted that the dip stick was broken could this be the problem if so could it be trapped in an engine oil port/hole.
Is there anyway it could work its way to filter or would it just sit in the sump and cause no problems.
When the engine oil cap is removed oil is blown out of the filler hole is this ok or does this suggest that the oil presssure to high. (Know if you see this in a motor car engine it means problems)
Hope someone can help dont fancy stripping engine down if i dont need to.
