As promised here are the pictures of the completed installation of the accessory / battery charging socket on the new 09 GTV. Total cost $10.35 (Not counting the charger).
Also a few not so good pic's of the new toy.
Also a few not so good pic's of the new toy. |
Vespa 50 Special, Honda CG125
Posts: 283 Location: Bristol, UK |
Posts: 16295 Location: Toronto, Canada, Fort Lauderdale, Florida |
Nice job, did you have to run wires from the Left Knee pad to the battery?
You should post this in the Project Reports as well if you haven't already. |
Junglizt1210 wrote: just 1 mile in, on your scoot, and you've put a mod on it already?! 8) looks great btw! Yes sometimes I think I have more fun doing mod's and working on bike's than using them for what they were intended for. BTW: what should I consider for the next mod? I am thinking a pipe change. Guess I won't do that for $10.00 |
Benito wrote: Nice job, did you have to run wires from the Left Knee pad to the battery? You should post this in the Project Reports as well if you haven't already. |
GTS250ie, ET4
Posts: 1244 Location: cincinnati, ohio, usa |
OK Guess the socket still is useable for a GPS, etc, because it wired directly into the battery?
'07 GTS-250ie - sold and gone
Posts: 2023 Location: the Queen City of the West, aka Porkopolis |
Good clean workmanship.
IMHO, a better place for that inline fuse would be down at the battery. If that hot wire ever shorts to the ground wire, or to chassis, you've got a fire on your hands. |
Papa Smurf wrote: OK Guess the socket still is useable for a GPS, etc, because it wired directly into the battery? |
Cincinnati John wrote: Good clean workmanship. IMHO, a better place for that inline fuse would be down at the battery. If that hot wire ever shorts to the ground wire, or to chassis, you've got a fire on your hands. It would be very simple to add another at the battery end. Will have to give that some thought. Thanks |
JimmyLee wrote: I know this isn't related much to your mod, but you own best modern scooter, ever. I have since installed a fuse link at the battery end of this mod. (protected at both ends now) Hopefully all goes as well when I install the LV pipe and the Corsa next week. |
