Hello again everyone, I have been out of the country for the last 4 months. I was In Egypt and it was a mixture of everything from completely awesome to extraordinary infuriating. But that's now why I'm here.
I'm having some trouble with my start ups. I have read some other postings on the issue and it sound like sometimes the posters are posting about a problem like mine but the responses always seam to take it somewhere else.
The Problem: this has been happening with time more and more often now it happens about 3/8 of the times I try to start it. The brake is engaged; I press the start button and hear nothing but a spinning sound. The longer I hold the start button the faster it spins. I let go of the start button then the spinning quickly slows down and stops. I would say 1 to 2 seconds after I let go of the button the momentum of the spinning has gone. I try it again sometimes it happens again but it always eventually starts.
My thoughts: I'm thinking something with the starter. Then I read some prior posting and the spark plug boot and coil kept being mentioned. I went and tried it and now have to say with pretty much confidence that it can't be the spark plug or boot. When I disconnect the boot and try to start it happens what I expect. The starter engages and tries to turn over the engine but without the spark of the plug no combustion. So I believe my problem comes before the sparkplug on the chain.
In my head the starter should engage and spin some kind of wheel that turns the cylinder and sucks in some juice which then ignites. I think what is going wrong is that somewhere between the starter engaging and spinning the "some kind of" wheel there is something going wrong.
What do you all think? I know I wrote a lot and for that I apologize, just want to give you all the chance to make the most informed opinion. Do you all think one of these "wheels" have some broken teeth and the wheels are sitting right which sometimes makes the starter just spin without catching? And whatever hypothesis you all might have can you all maybe give some suggestions on how I can check on that possible hypothesis without first taking it all apart. Maybe what I can do to dismiss certain possibilities.
Alright everyone thanks for taking the time to read this and if you all want to comment thanks for taking the time for doing that too.
Great to be back in the U S of A even though it's a rough time!
