piaggio 2007 bv500
piaggio 2007 bv500
Yes, in addition to owning the BV500 previously mentioned in this forum with a problem that has since been resolved, I also have the LT150. I have managed to knock it over a couple of times and now the mirror on the right-hand side is loose. Is it just a question of tightening the bolt under the rubber covering to get it to stay in place? Thanks...because if it is, that is something I should be able to do myself.
@dougl avatar
El Macho
KTM Super Duke 1290, Vespa GTS 300
El Macho
@dougl avatar
Yes. Turn the mirror to the desired position and tighten down the locknut (not a bolt!). If it is the same as an LX or ET it is a 17mm wrench.
[ Time: 0.0091s ][ Queries: 3 (0.0027s) ][ live ][ 313 ][ ThingOne ]
