Wed, 08 Oct 2008 21:55:26 +0000
P200, 150 super, ET4 190
Wed, 08 Oct 2008 21:55:26 +0000 quote
I need some tips on the best way to prime the oil pump on my 73 Super. I thought I had it worked out using air pressure but Im not sure. ANy help would be appreciated.
Wed, 08 Oct 2008 22:40:46 +0000
bunch "o" bikes
bunch "o" bikes
Wed, 08 Oct 2008 22:40:46 +0000 quote
If I've had everything appart,
-hook up oil line
-remove carb
-remove spark plug and squirt a little oil in the cylinder
-twist throttle so pump arm is all the way forward
-kick like a mad man
when you see oil welling up from the hole in the gasket, re-attach carb
this way I know the oil is getting through the system
...edit... you can do this with the carb attached but it's hard to see the oil dribble out o the hole
or
hook everything up and run the first 1/2 tank of gas pre-mixed, the pump "should" self prime...you can let an air bubble into the oil line and watch if it moves toward the pump
sean s
Thu, 09 Oct 2008 02:23:48 +0000
Thu, 09 Oct 2008 02:23:48 +0000 quote
or
sean s
This is what i do. A little bit of premix in the first tank ( better to run only a SMALL amount of gas, even, if you're really careful about this stuff ...like, maybe only a quart or so, premixed ) and then make sure an air bubble in the line moves towards the oil pump once the engine is running.
Fri, 10 Oct 2008 15:59:22 +0000
Fri, 10 Oct 2008 15:59:22 +0000 quote
Thanks Fellas!
Thats pretty mich what I had done.
I used some compressed air to push the oil up the line until it was coming out of the line I then attached it to the carb. Fired the engine up with a bit of premix in the tank and went for a ride.
So far it seems to be ok.
Fri, 10 Oct 2008 16:07:39 +0000
Olivia Newton-John
p200, vbb, gt200, px150, vnb
Olivia Newton-John
Fri, 10 Oct 2008 16:07:39 +0000 quote
that's what i did on my stella as well. 150 miles later, no problems (crosses fingers).
Wed, 15 Oct 2008 13:04:43 +0000
PX200E X 2
PX200E X 2
Wed, 15 Oct 2008 13:04:43 +0000 quote
c'mon dave, don't you want to seize up next weekend
Wed, 15 Oct 2008 13:20:22 +0000
Wed, 15 Oct 2008 13:20:22 +0000 quote
+1
Also used this technique on my Derbi after replacing the oil pump. Put 1.5 liter of premix in the fuel tank. Filled the 2T oil tank to the very top. Rode it for a while and then checked the oil lines for bubbles and the level of oil in the 2T oil tank to be sure it dropped.
And Bob's your uncle!
Al
  DoubleGood Design
[ Time: 0.0277s ][ Queries: 3 (0.0078s) ][ Debug on ][ 298 ][ Thing Two ]
