@stevers avatar
2007 Vespa GT200
@stevers avatar
2007 Vespa GT200
Hello again everyone, it's been awhile...
The topic says it all. The GT is smelling real badly of gas every time I am running it. I haven't overfilled recently, and there is no leak to be found. Runs fine and starts up as usual, but makes the garage smell awful. Any advice would be great.
Thanks!
check your fuel lines for cracks... *shrug*
I've picked up two that had cracks in them... pretty bad ones. Not really noticeable until you bend them a little bit. If it's still wrapped in that cover with another hose it will likely only be on the ends by the fuel filter and the carb.
Also check the hose on the other end of the filter.
@rkoch avatar
GT 200L 1600 Meanstreak
@rkoch avatar
Re: Major Gas Fumes...no recent overfill, no leaks...
Thanks!
CK the seal on top of fuel tank sending unit. Mine dried out had to remove and permatex it. I removed the tank . Lesson for me .
Spent an evening doing it .No more smell here. Good luck Rich
@viva_sicilia avatar
2004 Vintage Green GT200
the same thing that happened to ratboy happened to me. the mechanic squeezed the line and gas came squirting out. i replaced the one line, still had the smell, then found cracks in the other. that's probably it.
[ Time: 0.0129s ][ Queries: 3 (0.0058s) ][ live ][ 313 ][ ThingOne ]
