I am convinced that the lack of increase in power at the top end is due to the cylinder head. I hear this over and over again about modded ET4.
I am planning to put on the 187cc Malossi. I already bought one.
The cylinder head channels are to be milled out to a bigger diameter and smoothed out.
As this is a 2 valve head compared to the 4 valve head of the GT 200 I maybe put in bigger valves as well....
The carb I am replacing with a 29 mm walbro from a GT 200 I already bought for only $20.
Anyone has an idea what I will gain? Laughing emoticon Laughing emoticon Laughing emoticon Laughing emoticon
Will it be similar to the power of the GT 200?
@tfauch avatar
@tfauch avatar
See: Piaggio Engines and look at the difference between 2 valve and 4 valve and air cooled and liquid cooled engines.
Tim
1962 Lambretta TV175, 2001 ET4, 1972 Honda CB350 1969 Honda CL350
My ET4 keeps up with stock GT's all day long and I didn't do any machining at all.
@orbit avatar
06' Vespa LX150, 73' Serveta Jet200, 64' Vespa GL150
@orbit avatar
Not listed in the PDF that TFauch linked to, but the stats on Piaggio USA's site lists the FLY 150 as having a 150cc air-cooled 4-valve SOHC engine.
I believe that other than that, the LX/ET and the Fly have the same LEADER engine.
@scooter_west avatar
Sponsor
Sponsor
You might want to consider making a GT200 airbox fit to go with that carb. Those carbs are very particular to incoming airflow, and those airboxes are designed very specifically for those carbs. I don't have any real experience with doing this mod, but it's one of the things that popped into my head.
@bryce-o-rama avatar
Peugeot Looxor
Peugeot Looxor
I have a feeling that the 4-valve air cooled thing is a typo. The multi-valve layout is a large part of why the liquid cooled LEADER and QUASAR engines make more power than the air cooled ones. The cool thing about the 4 valve LEADER engines is that they still only use 2 rocker arms, and a two lobe camshaft. Someone enterprising and engineering savvy could potentially make an air cooled version of the 4-valve head, which would likely unleash more power from that engine. When I did the valve work on my engine, my friend and I looked at the head and realized there was a lot of flow work that could be done to open the ports and make them smooth. But it would cost a fair amount to get it done right. With other modifications, it could be useful, but I am not sure how effective it would be on its own.
@andrew avatar
2006 Fly 150
@andrew avatar
2006 Fly 150
Yes, I'm fairly sure it is a typo (haven't taken my Fly apart enough to actually look), but the paper brochures state 2 valves, and the dealer said 2 valves. I sent an e-mail to Piaggio USA about correction their website a month ago but heard nothing back (big surprise).
[ Time: 0.0122s ][ Queries: 4 (0.0065s) ][ live ][ 313 ][ ThingOne ]
