My two latest mods. on the GTV.
1.Installed the side stand. (In my opinion, that's a got to have item)
2.Disconnected the charcoal canister system.
I left everything in place, just in the event I ever had to do a reconnect. To reconnect, all I need is a ΒΌ" two ended barbed brass fitting for reconnection.
Drilled a small hole in each brass plug for venting.
Could be my imagination, but engine seems to run a might smoother at the
Higher RPM's .
