The 26-footer will be here at noon today, and then I'll have until Sunday to load it all, including the GTS.
It is going to be a low-riding UHaul, with a long ramp, so it won't be that steep, just long (and a bit over 2' wide).
Would you walk it up, pushing it?
Would you walk it up, with motor support?
Would you ride it up?
I'm thinking of riding it up (and the neighbor will have to take pictures, of course).
Inside, I'll tie it to a side wall. There is no way to strap it like you would on a trailer--no tie downs on the metal floor. I'll cushion it with stiff foam and wrap it in blankets, so it should be fine.
I think it is the right thing to stand it on the center stand, so it won't bounce on its own suspension, as the truck goes over uneven roads, thus chafing away on the contact points with whateve is near to it. I think it will go in last, hopefully with nothing close to it (the truck should be big enough to allow for that).
Any constructive thoughts or good advice? I would appreciate it.
