Mon, 13 Oct 2008 20:43:45 +0000
Mon, 13 Oct 2008 20:43:45 +0000 quote
This weekend I will be replacing the coil and condenser on my 68 Sprint. I was wondering if anyone had the exact location of the condenser itself? Do I need to get to the stator plate for this?
Also, if anyone had any good advice on installation would be great too.
Thanks!
Mon, 13 Oct 2008 20:47:24 +0000
Mon, 13 Oct 2008 20:47:24 +0000 quote
The exact location? It's under the flywheel, bolted to the stator plate.
Pull your fly - you've likely got a self extracting flywheel, and you'll be looking right at it.
There you go : all done for you with pictures...
http://www.scooterhelp.com/tips/engine/flywheel.old.vespa.html
Mon, 13 Oct 2008 21:22:08 +0000
Mon, 13 Oct 2008 21:22:08 +0000 quote
Thanks again Eric. Would I really need a flywheel holding tool?
This is the condenser I had ordered, is this correct?:
http://www.scootersoriginali.com/osc/product_info.php?cPath=1_5_50_211&products_id=1126/
And on the stator plate, which one is the condenser?
Mon, 13 Oct 2008 22:09:51 +0000
Mon, 13 Oct 2008 22:09:51 +0000 quote
I jam the handle of a decent sized screwdriver in between one of the fins on the flywheel and either the kickstart lever or the gearbox, depending on which direction i'm going on. ( well, i dont now because i have the right tool, but i used to )
The condensor looks like a small battery - maybe half the length of a AA battery and 50% wider. It's looking right at you on that picture.
Mon, 13 Oct 2008 22:16:30 +0000
Mon, 13 Oct 2008 22:16:30 +0000 quote
Very cool, I see it now. Thanks again for your help Eric!!
  DoubleGood Design
[ Time: 0.0305s ][ Queries: 3 (0.0109s) ][ Debug on ][ 298 ][ Thing Two ]
