Mon, 13 Oct 2008 20:46:53 +0000
788 94491/1958 allstate
Mon, 13 Oct 2008 20:46:53 +0000 quote
Puting nut on tap inside the tank
Do I need to glue the nut in place in side the tank?
Then bend the vent tube were I can turn the tap
360 to tighten it up
Mon, 13 Oct 2008 20:52:10 +0000
Mon, 13 Oct 2008 20:52:10 +0000 quote
You really need the crowfoot wrench to put it on tight.
Or make one by heating up the correct size ( 22mm? ) spanner with a torch, bending it to the proper angle, and then using that.
Any other method won't really work.
Mon, 13 Oct 2008 20:58:27 +0000
Mon, 13 Oct 2008 20:58:27 +0000 quote
Have Wrench - going back out to shop to see if I left out the washer!
Mon, 13 Oct 2008 21:05:35 +0000
Mon, 13 Oct 2008 21:05:35 +0000 quote
My method is usually to hold the nut in place with the wrench, and rotate teh bottom of the tap with my hand or possibly a vice-grip (carefully!)
after a while, the nut catches and just screws on by itself, and you don't need the wrench at all.
Mon, 13 Oct 2008 21:25:36 +0000
Mon, 13 Oct 2008 21:25:36 +0000 quote
I am a dumb A - -! I did leave the washer off - I thought I cross treaded it, as it would not tighten up. So I made it past Fuel Tap 101.
Mon, 13 Oct 2008 21:49:06 +0000
LX 150
LX 150
Mon, 13 Oct 2008 21:49:06 +0000 quote
except to hold the nut in place apparently.
Tue, 14 Oct 2008 00:45:58 +0000
Tue, 14 Oct 2008 00:45:58 +0000 quote
Ok the nut went right own - and tightend right up!
Thank you - thank you. Do I pass uh do I? I gotta know
  DoubleGood Design
[ Time: 0.0234s ][ Queries: 3 (0.0036s) ][ Debug on ][ 298 ][ Thing Two ]
