deli-x wrote:
I wonder how much work will need to be done to modify the MP3 for offroad.
If you are using fire trails like in the video, then it's possible.
The enemy is dirt. You need to service your air cleaner element daily in dusty/off-road conditions.
1) It is oiled foam, so it needs to be washed out in soapy water and then re-oiled using appropriate filter oil, making sure that
all the excess oil is squeezed out.
2) You could also use more foam on the air intake area on the outside of the air cleaner assembly, as a pre-cleaner.
It's messy and time consuming, but absolutely necessary. Any dirt or dust that gets past becomes an abrasive paste in the engine oil and will rapidly wear out the engine. Because some still gets past anyway, it pays to change the engine oil more frequently than suggested.
3) The other hazard is the auto trans area, which I believe is vented. If air can get out, dusty air can also get in and accelerate wear of the belt and pulleys. You could use foam over the air exit and entry points and lightly oil this also to trap dust.
4) More suitable tyres.
Cheers, and all the best
Trevor G
