I have got a 180f Vespa ET2 150 which is been in an accident. I have installed a new ignition and CDI unit. I have got it running. However when I get the engine started it will not go. Thanks to you, I have also looked at some of your technical description and I have been able to open the clutch/variator cover under BELT/VARIATOR change discussion area. Thinking that belt might be torn or what have you..... But it seems fine. what should I do next!!??.
Many thanks in advance for any help you can give. me.
Regards...
